I may have F'd up my deckplate mod
NAPA sells it. Scrape the crap off and redo it. Then you will not need to worry.
Swallow this one: Why would they make "sensor safe" silicone in the first place then?
Lighting a stream of lighter fulid is ok, most of the time. No all of the time.
#25
Oh oh, I can answer that one. Finally I get to feel like I know something and answer a question instead of asking them all the time.
The deck plate mod. allows for more air flow into your engine by putting that huge hole in the front of your air box, and combined with an AMSoil Air Filter there is a noticible difference. The point of the deck plate is that when you got off-road you can put in the deck plates plug and cap the hole, stoping the mud and water from getting in that normaly would if left open. You lose the air flow but protect you filter. It's a great bit of versatility offered for a great price(about 10 bucks for the deck plate). If you haven't done it I would highly suggest it, I just did mine latley and I'm really loving the diff I feel. Just make sure to get sensor safe silicone(unlike I did) so you can avoid sweating it out like I am right now, it's been 2 days and no lights, I think I'm in the clear.
#29
Originally posted by C2damuthafuqinLO
And what if u never off road...and don't even use sealant?
Once silicone cures there is nothing to worry about. There is no need to go back and remove old silicone, it won't be releasing fumes anymore.
There really is no need to seal the backing of the deck plate anyway. Have any of you noticed all the drain holes in the bottom of the airbox? Just covering the big hole with the lid on the deck plate so it won't get a BIG gulp of water all at once is plenty fine enough.
Gadget
www.GadgetOnline.com
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
53
Feb 1, 2016 05:46 AM
