How much oil is too much or Am I the dipstick?
Old Nov 27, 2009 | 03:24 PM
KrashDH's Avatar
How much oil is too much?
Just curious I know it sounds dumb, but just changed my oil tonight and by the dipstick, its a bit high. I put in the recommended 5.7 qts (probably a bit under that actually) ran it to op temp, then let it sit. Checked it, about an eighth inch over. Letting it sit for a long time brings the oil mark a bit more than a eighth over the line. I'm sure there was a bit of oil left over in there because I drained it probably an hour after I got home.
I know the harms of having too much oil, but just curious with these trucks how much is too much? There are no signs of anything weird like white smoke or what not, and like I said, i went by the book for the amount to put in.
Old Nov 27, 2009 | 08:47 PM
brian2sun's Avatar
You'll be fine like that, 5.5-6 qts is the right amount (6 if you're using the oversize filter). If you were reading a full qt. high, I'd say drain some, but I wouldn't even bother in your case - you won't be blowing any seals.
Old Nov 27, 2009 | 09:17 PM
raydouble's Avatar
I've heard everything from 5.5 to 6.5 quarts.....I use 6 quarts w/ the V8 "D3" OEM filter. Always right at the top line.
Old Nov 27, 2009 | 09:20 PM
KrashDH's Avatar
thanks guys figured I'd be fine just wanted to check.
Old Nov 27, 2009 | 09:27 PM
pkt1213's Avatar
See that's odd cause I put in 1qt of lucas and just a hair under 5 quarts and it still wasn't at the full mark.
Old Nov 28, 2009 | 04:20 AM
smuook's Avatar
You could always just drain the excess off by cracking opening the drain bolt to where it slowly drips into a drain pain. Although I don't think the 1/8 inch is going to be a problem, why take the chance?
On the Tacoma V6 5VZ, it takes 1.3qts to go from the low line to the high line... so if you fill to about 4.5qts, you can fill to the low line instead, and then adjust from there. Just remember you lose about 1/3 qt to the oil filter.
Old Nov 28, 2009 | 04:48 AM
Mtn Mike's Avatar
There must be some variation somewhere from engine to engine. I've always wondered why. Maybe it is because dip sticks made aren't accurate down to the level of 1/2-1/8 inch. My owners manual states 5.7 Q when the oil and filter is changed. However, at every oil change I add a full 6 quarts and I am consistently 1/8 inch below the "F" on the dip stick. This is a completely stock engine and OEM filter. I've posted on BITOG and found a lot of people have the same variation.
Anyway, I've heard that 1/8-1/2 quart up or down isn't a big deal.
Old Nov 28, 2009 | 05:24 AM
emptypockets's Avatar
I use the recommended sized filter (#3614) and add 6 quarts at every change. My dipstick reads right at full mark. When I change my filter between oil changes, it drops some, but not a lot. I'm running Schaffer 7000 oil FWIW and love it. I change filters at 3,500 miles, and do a complete oil change at 7,000.
Old Nov 28, 2009 | 06:51 AM
KrashDH's Avatar
Ha it seems like we have a comedian on the site. Legit question though, its not worth risking blowing any seals and ruining an engine because of oil. I put in the exact amount and have been putting in that much since I owned the truck. This is the first time it's read over the top. So to whoever changed the title of my thread thanks.
Old Nov 28, 2009 | 08:30 PM
Evilmunkey's Avatar
I use about 5.6 to 5.8 qts in mine and I end up even, but a lil over you'll be fine. Not is it conventional or Sythetic (Royal Purple 5w30 FTW!!)
Old Nov 28, 2009 | 10:23 PM
VSU_4runnin's Avatar
youll burn off that excess by the time your next change comes around
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
93toyoguy
Aug 2, 2015 07:41 PM
adammtb
Jul 27, 2015 11:57 AM
calderp
Jul 27, 2015 09:58 AM
