How many miles on your 3rd Gen 4runner?
Old May 26, 2010 | 03:22 PM
  #61
tunnelmotor99's Avatar
About to roll over to 180k.
Old May 26, 2010 | 04:08 PM
  #62
bullcrew's Avatar
177k on the 98, new TB, TPS, water pump, tensioner pulley and thats it.... Motor is silent and runs like a dream...
Old May 27, 2010 | 07:37 AM
  #63
j-money$$$'s Avatar
hit 225,000 this week. and the stock rear axle seal blew almost exactly 225,000 haha
Old May 27, 2010 | 07:51 AM
  #64
badattitude's Avatar
111,500 on my 1999 SR5, runs like a tank! No problems
I think $4,000 for a 2nd gen with 386,000 is too much; even for a nice one owner truck, just my .02. I like to see 4runners hold value though.
Old May 28, 2010 | 04:41 AM
  #65
Demosthine's Avatar
I have 305,000 on my '98 4Runner SR5. I've had no major issues at all. I've spent some time and money tracking down several issues, but part was my fault.
I had warped rotors that two separate turnings failed to fix and am in the middle of a suspension problem. Once I found out the problem, it was a quick and easy replacement fix. I didn't install the shock bushings on my front shocks, apparently, and it's collapsed both bushings, plus it wore an oval shape into the strut mount. This is a quick and inexpensive fix to be done tonight.
Otherwise, I am completely happy with my 305k+ miles. They are excellent vehicles.
Old May 28, 2010 | 05:28 AM
  #66
mooseT's Avatar
140k
140k miles on my '01 SR5. Only major issue so far is replacing the radiator due to milkshake. Bought it 9 months ago, and I don't think the previous owner had any major issues. Other than that, I am mostly starting to consider replacing or sanding/painting rusty parts (e.g., replacing rusty bolts and pipes, sanding/painting rear diff). It is troubling how rusty the diff gets. I also need to replace the spare tire - it is so rusty that it won't hold air and it looks very fragile.
Old May 28, 2010 | 07:22 AM
  #67
gdutch's Avatar
If you had the milkshake, you might as well start socking money away, because your tranny isn't likely to make it much longer.
Old May 28, 2010 | 08:29 AM
  #68
dougiefreshmx's Avatar
145k Still going strong
Old May 28, 2010 | 12:33 PM
  #69
Garth's Avatar
230K+ on my 1998...nothing major has gone wrong!
Old May 29, 2010 | 02:07 PM
  #70
j-money$$$'s Avatar
Mine has had it's issues. First off at 170,000 the transfer case decided to self distruct, and then I had a clutch break the the finger springs off, and then I had a valve issue, and fuel injector fail at the same time, recently I broke a lower ball joint and the driver side front tire/ steering knuckle fall off In 4lo thank god. And now a rear axle seal this week. Ugh!!!
Old May 30, 2010 | 07:53 AM
  #71
X-AWDriver's Avatar
Just passed over 158k yesterday and my mom just crept past 90k on her '99 Limited.
Old May 30, 2010 | 09:46 PM
  #72
bullcrew's Avatar
1998 4runner 178k now got it a few Ks ago. Put TB, TPS, Water pump, Thermostat, tensoner pulley and NO engine noise what so ever...
5spI got 20.5 hwy and 18.5 mixxed use with 265x75x16 and stock gearing, Im pretty excited.
I gave up my 03 landrover disco with 55k miles for this and cash as Ill be running between Boise and Socal ever month and all over down there. Never had an issue with the disco but I trust this vehicle in the middle of nowhere for easy parts and reliability over the disco....
Old Sep 4, 2010 | 06:51 PM
  #73
jreask's Avatar
200,194 as of today on my '01 SR5. NO major problems. Normal maintenance only. I want to go to at least 350K.
[IMG]https://www.yotatech.com/Name:  014runner001.jpg
Size:  72.8 KBName:  014runner001.jpg
Old Sep 4, 2010 | 07:10 PM
  #74
hogman73's Avatar
i picked up my 02 sport edition from the original owner for 5800 and he had given my a folder full of service records. This 4 runner has 179,300 and so far so good. timing belt was replaced at 93,000 and i am wondering how soon before i have to put another one in ?
Old Sep 4, 2010 | 07:11 PM
  #75
Brad.'s Avatar
141K. can't even imagine taking it another 100K. Seems possible though. Cheers everybody!
Old Sep 4, 2010 | 07:14 PM
  #76
jreask's Avatar
FSM calls for 90K miles timing belt intervals. SO, you are about due. I also think some others have gone over 200K without a change. IF the belt breaks, it won't hurt anything, but you won't be driving it, you will be riding in the tow truck.
Old Sep 4, 2010 | 07:21 PM
  #77
hogman73's Avatar
Thanks jreask so what am i lookin at for cost on a timing belt installed by local garage 600 ? i didn't look to see what the original owner paid for the first one
Old Sep 4, 2010 | 07:26 PM
  #78
FogRunner's Avatar
Coming up on 300K and 7000 hours on my 01 4runner and all is still good. The only thing I'm having to replace is the fan/pulley bushing bracket.
I wish I could get half of this reliability out of my 2006 Jeep TJ. I swear it must have been built on a Monday or Friday.
FOG
Old Sep 4, 2010 | 07:30 PM
  #79
jreask's Avatar
I just had mine done at the dealer a few weeks ago. It had 198K on it and I think the original owner never replaced it. I decided to get it done before it broke. To replace the timing belt, tensioners, water pump, all drive belts it was $680 ( I prefer the dealer for this service). I also had the tranny fully flushed for $150. Hope this helps.
Old Sep 4, 2010 | 07:44 PM
  #80
hogman73's Avatar
okay that seems pretty good for what you all had done
