How do you 1st Gen's take your tops off???
Old Apr 27, 2004 | 10:25 AM
deathrunner's Avatar
How do you guys, especially the ones with lifts take off yer tops???
Where do your est the top and how.
I attempted to take it off on my own and I scratched up the side, when I first got it.
I wish I had a garage, I would build a pulley system to lift it and then store it.
Summer's coming and I want to use my bikini top. Toss me some suggestions.
-Seth
Old Apr 27, 2004 | 10:27 AM
The Rusty Gear's Avatar
-Seth
Use at least two people. I usually open the side sliding windows to get a hold of the top.
Old Apr 27, 2004 | 10:59 AM
Cool. How do you rest it? Do you ever have problems with teh seal when you replace it? I haven't but have always heard that that was a problem.
Old Apr 27, 2004 | 11:33 AM
runnerboy97's Avatar
when you take it off, just dont rest it on the seals. lay it upside down, or like put it over like a table or somethin, other than that it should be a 2 person job
I rest it as if it were still on the truck. I have not stored it on its side because I'm worried it may flex the side it's resting on too much.
I've not had much problems with the seal. After putting the top back, I've sometimes had to lift one side up and cram the seal back in, but as far as re-sealing against the outside, I've had no problems even if the seal did not fit *properly*
EDIT: But upside down like runner97 suggested sounds like a better option if you are storing it inside (I store mine in the back yard)
Old Apr 27, 2004 | 12:17 PM
I have been storing in with the back edges (Rear window) on the ground and I lean it up against a wood rack, and I cam buckle it down, so it doesn't fall. I place a thick blanket under the edges that touch teh floor (don't want to scratch the paint).
Good ideas. Thanks
Old Apr 27, 2004 | 03:39 PM
pat317az's Avatar
I don't have one but it seems like putting it on a couple saw horses would be a good way to go. It would be upright (won't collect rain), off the seal, and the saw horses fold up and store easily when not needed.
just my .02
Old Apr 27, 2004 | 03:47 PM
seaflea's Avatar
just my .02
That is exactly what I do. I also have a couple of 2x4s that are about 6 feet long that I screw to it to keep it from bowing out over the long summer.
Old Apr 27, 2004 | 03:48 PM
SteveO's Avatar
Reading through this thread, I was thinking about how to really store it so it would stay clean in the garage, not flex and be out of the way. What do you all think of this:
1) Measure the inside of the top, from side to side before it is removed.
2) After removing the top, place it on a couple of 2x4s and hoist it high out of the way of any cars.
3) After hoisting the two 2x4s with the top, use a couple of ratchet straps to keep the bottom of the top at the same distance as when it was sitting on the rig, to keep it from splaying out when sitting on the 2x4s.
Old Apr 27, 2004 | 04:53 PM
cabbage's Avatar
Finally found the pictures, saw it in a thread somewhere... here it is: http://www.norcalbigdawgs.net/Gallery/album70
Old Apr 28, 2004 | 08:31 AM
That's what I have been thinking about doing,but I have no garage. I was thinking about sinking a couple of 4x4's in my driveway and lifting it with those.
vanion2
Jul 29, 2015 06:17 PM
calderp
Jul 27, 2015 09:58 AM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
