How to do a deckplate mod
Old May 26, 2005 | 05:04 PM
ScottyBean's Avatar
Ok, I have searched, and found nothing on exactly what it is and what it does.. i read people talkign about how you have to reset your ecu? i thought your just cutting a hole in the side of your intake? Can anyone explain this to me and how to do it etc, because I have no clue... Thanks
Old May 26, 2005 | 05:11 PM
Corey's Avatar
Co-Founder/Administrator
Have you looked in the Tech section?
https://www.yotatech.com/forums/f63/
I know there are articles in there.
Old May 26, 2005 | 05:13 PM
kevin444's Avatar
1. Cut the hole in front of the airbox.
2. Pull out the efi fuse which is typically a 15-20amp fuse in the fusebox.
Old May 26, 2005 | 05:16 PM
Gangus2006's Avatar
err....https://www.yotatech.com/~corey/tech/techpage5.htm
take your pick..
basically the deckplate part is cutting a hole in your airbox. but when you do anything performance related to your truck, you need to reset the ECU. Just pull the negative battery cable and leave it disconnected for a while...
Old May 26, 2005 | 06:10 PM
EWAYota's Avatar
when i did mine, all i did was remove the airtube that runs from behind the headlight into the box (automatically making a 3in hole), then i drilled holes in the bottom of the airbox just incase water gets in, it has a way to get out. plopped in a k&n airfilter, and disconnected the battery. i can tell a difference with cold temps obviously and it makes a little rumble, sounds like a 5 cylinder!
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
