High temp gaskets?
Old Oct 9, 2004 | 01:10 PM
midiwall's Avatar
High temp gaskets?
So I've now burned through my 2nd set of gaskets in 6 months on the exhaust crossover pipe... time to find something better.
I knew that the material I bought (the highest temp stuff I found at Schucks) wasn't gonna last long, but I was hoping for more than a month.
Anyway... what should I be looking for? Something I can buy online? A preformed metal composite? The flange in question is just a standard 2 1/4" exhaust fitting.
Thanks for ideas and web links.
Old Oct 11, 2004 | 01:13 PM
midiwall's Avatar
*bump*
Old Oct 11, 2004 | 10:35 PM
humanoid's Avatar
Mark:
Not sure if this is what you are looking for...
http://www.customtacos.com/ubbthread...t=1#Post375215
Old Oct 11, 2004 | 10:46 PM
jimbo74's Avatar
dont they make copper gaskets for that?
Old Oct 11, 2004 | 10:51 PM
humanoid's Avatar
Old Oct 12, 2004 | 08:21 AM
MTL_4runner's Avatar
Originally Posted by humanoid
Mark:
Phenolic won't hold up to those type of temps for very long (intake temp with a turbo is much less than in an exhaust).
Mark, you might want to take a look at this as it relates to exhaust gaskets.
http://www.chevyhiperformance.com/techarticles/67519/
You might think about making your own gasket with some soft copper and a dremel tool.
Some good advice: Even the best wire-reinforced gasket will burn through if bolt torque loosens. You can tell a header or collector gasket is leaking by the carbon track on the gasket. Often, just retorquing the bolts will produce a leak-free seal.
Old Oct 12, 2004 | 08:57 AM
midiwall's Avatar
Thanks for the responses guys...
Jamie; that's exactly what happened with the original gasket. Many moons ago I'd heard a ratttle under the truck, found it to be one of the bolts on the crossover and tighted it up. About 2 weeks later, the tell-tale "pfft-pfft-pfft" started. That was the first "edge burn".
Soft copper and the Dremel seems like the way to go... I'll check Summit, and I may just try some copper flashing from Home Depot... Hmmm...
Old Oct 12, 2004 | 09:11 AM
You want to find the purest copper you can get because that will ensure it is soft and maliable, some of the flashing or copper sheet may be alloyed with other metals and won't compress as much as you would like to get for use as a gasket material. Most speed shops can get both copper and the wire reinforced fiber gasket material in sheets for a DIY gasket. We use to use the fiber stuff to make header gaskets all the time if we couldn't get what we needed. Worked very well.
Old Oct 13, 2004 | 02:19 PM
midiwall's Avatar
'k... time to start smelting pennies and skimming out the tin.
Thanks Jamie!
Old Nov 5, 2004 | 09:45 AM
midiwall's Avatar
fyi...
as a follow-up, I ended up getting gaskets from Summit Racing:
http://store.summitracing.com/defaul...237+4294921566
$4.88 each, free ground shipping but Summit's $8.95 handling charge sucked. They were still cheaper than I found elsewhere online, and I couldn't find anything reasonable locally.
Old Nov 5, 2004 | 03:12 PM
FattyCBR's Avatar
I made my own for the cat gaskets out of .125 copper that I cut and annealed myself because they're so thick I can reuse them forever.
Old Nov 5, 2004 | 04:01 PM
midiwall's Avatar
Yeah... that came up above somewhere (or I may have gotten that as a suggestion offline) but I don't have the time/energy/know-how to do something like that. I was happy paying $5/each to just have them done and ready to swap-in.
the1998sr5
15
Jul 14, 2020 08:35 PM
dumpster84
Apr 30, 2016 06:03 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Jonny246
Jul 12, 2015 04:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
