HID kits on ebay and in general
Old Nov 29, 2004 | 11:56 AM
dexter's Avatar
Post HID kits on ebay and in general
okay so iv got some money and after comming home for thanksgiving and back i want hids. the local 4x4 shop in missoula has some that they will sell, instal, and aim correctly as to not blind others for around 500-600 bucks maby more. then on ebay they have kits going for around 175-365 and it would be about 200 bucks for instalation. these kits come with osram or hella balasts. which do you guys think i should get? price is a huge issue otherwise id get a set from an sc430 or a catz system and get custom projectors mounted in my existing headlamps by that company.
thanks
Old Nov 29, 2004 | 12:02 PM
Bratik's Avatar
thanks
You should save some money and do it once correctly, meaning: getting projectors that were design for Xenon/HID bulbs, this is the only way to get great visibility without blinding other people. Check out HID Planet for a lot of information on HID. I just completed retrofitting Infinity FX projectors into my 2000 headlights. Good luck!
Old Nov 29, 2004 | 12:07 PM
2001Millrunner's Avatar
do you mean you're going to get the projectors? best kits that are out there are philiphs Ultinon Xenon kit and also Katz. Those run around $500 alone, You'll also need projectors which are usually around $100-$150 on ebay(Audi, BMW are most popular and best ones) that's without retrofitting labor. someone on this board has also done this. Run a search and you'll find out more. He used aluminum foils to make his shroud. If you want one without projectors, you can get a shield kit to aim correctly for around $60 if i remember correctly. If you go without projectoros, install would be very easy for DIY.
Old Nov 29, 2004 | 12:10 PM
any pics?
Old Nov 29, 2004 | 12:11 PM
Bratik's Avatar
This is a post I made today
Old Nov 29, 2004 | 12:26 PM
kawaii005's Avatar
just buy the billet HID shields from casper electronics like i did, as long as you have an H4 it'll work. the D2S or D2R HID bulb just fits right in and you can aim your own headlights. i have them and there are no problems at all with beam pattern.
https://www.casperselectronics.com/M...Category_Code=
Old Nov 29, 2004 | 01:42 PM
so you can buy like an OEM hids(Lexus, Audi, Acura) and use this adapter to fit it in plug-and-play?
Old Nov 29, 2004 | 02:38 PM
4runner4me's Avatar
How much would you do mine for? Your truck looks great! How did ou get the front lens off and get it sealed again?
Old Nov 29, 2004 | 04:30 PM
98whtLmTD's Avatar
Yup, you miight need a screw to hold the bulb down from rotating though.
Gene.
Old Nov 30, 2004 | 03:27 AM
Bratik's Avatar
I can't do retro for you but I can point you to the correct people, You can find all the information about retrofitting Xenon/HID on Hid Planet. To take off the front glass, you'll need to preheat oven to 275, turn it off, put your headlight(one at the time) for no more than 7 min, than carefully pry out the glass with a knife. To seal it back use the same method.
Old Dec 8, 2004 | 12:29 PM
do you have a pic of beam patterns?
Old Dec 8, 2004 | 10:00 PM
98whtLmTD's Avatar
I'll take pics sometime this week of my projector beam pattern. I do however have pics of the Casper shields as kawaii005 said. Beam pattern is just like normal stock lights, just more intense.
coreyedwards7611
Jan 16, 2016 06:38 PM
jerusry
Oct 19, 2015 05:28 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
Edionne13
Jul 9, 2015 01:59 PM
