help where to find bolt torque
Old Nov 1, 2013 | 08:51 PM
BigHoss_27's Avatar
On 95 Tacoma 2.7 repair manual doesnt have all the torque specs for everything I had to take off head where can I find them
Old Nov 1, 2013 | 09:39 PM
Nestos4runner93's Avatar
I have the Chilton FSM. I just want to make sure your engine is 3RZ-FE? Under engine and engine overhaul 3-41 states torque specs for all bolts are 29 ft lbs (39 Nm) except the 2 front mounting bolts which are 15 ft lbs (21 Nm).
Old Nov 1, 2013 | 09:55 PM
BigHoss_27's Avatar
Yes that's correct but what about the water inlet and thing that bolts onto back of head I forgot the name
Old Nov 1, 2013 | 10:20 PM
HighLux's Avatar
I never go more than 12-15lbs into aluminum. Thts a good safe zone.
Old Nov 1, 2013 | 10:32 PM
BigHoss_27's Avatar
I mean I guess the most important is the head cams and intake and exhaust ? The egr and whatever is on back of head isn't as important
Old Nov 1, 2013 | 10:57 PM
HighLux's Avatar
That aluminum can strip quicker than you can imagine if your not careful....but yup the stuff through aluminum into the block needs more.
Old Nov 1, 2013 | 11:11 PM
BigHoss_27's Avatar
I saw somewhere about renting FSM but would it have every bolt torque spec in it
Old Nov 2, 2013 | 04:53 AM
rworegon's Avatar
Yes, the FSM has every bolt torque spec....at least the FSM I have does.
Old Nov 2, 2013 | 06:42 AM
BigHoss_27's Avatar
Could you possibly post pics of those I'm trying to get my truck together to drive to school and I can't find certain ones in the repair book but could you post all the torque specs on here or maybe text the pics
Old Nov 2, 2013 | 06:51 AM
BigHoss_27's Avatar
Also anything in FSM about dropping front diff
Old Nov 2, 2013 | 07:16 AM
rworegon's Avatar
Did you check FSM link in my sig line?
Old Nov 2, 2013 | 07:32 AM
BigHoss_27's Avatar
I didn't see a link
Old Nov 2, 2013 | 08:28 AM
BigHoss_27's Avatar
Is the link to buy FSM or look at and could you post it
Old Nov 2, 2013 | 08:33 AM
HighLux's Avatar
Have you ever used torrents? like utorent? and went to piratebay?
They have all the manulas to download there.
If you need help I can walk you through it.
Old Nov 2, 2013 | 08:39 AM
rworegon's Avatar
Here.....search it:
http://web.archive.org/web/201011261...fsm/index.html
I will assume you are on the mobile app and have the signature lines turned off. If not, and you are on a PC it's in the sigline as FSMs......
Old Nov 2, 2013 | 09:02 AM
BigHoss_27's Avatar
I download PDF and it says 96 but since its a 95 they will all be same
Sent from my DROID RAZR using YotaTech
Old Nov 2, 2013 | 09:09 AM
HighLux's Avatar
no 96 is totally different. you want the 93 one that floating around.
this one http://web.archive.org/web/201011261....1990.1995.zip
Old Nov 2, 2013 | 09:23 AM
rworegon's Avatar
HighLux, the Tacoma came out in mid-model year 1995. There was no Tacoma in 1993.
I bought mine brand new in August 1995 as it's generally called a 95.5 Tacoma. However, the paper FSM I have says 1995 on the cover.
Either the 1995 or 1996 FSM will work for the OP, IMHO. Seems this one would work just fine: 1995.5-1997 Toyota Tacoma FSM (2)(3)RZ-FE 5VZ-FE
Old Nov 2, 2013 | 09:41 AM
HighLux's Avatar
My bad..I kept thinking 4runner for some reason.
Im old.
Old Nov 2, 2013 | 09:51 AM
BigHoss_27's Avatar
Thank you guys so much though I found how to drop diff and the torque specs
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
mengquis
Jul 13, 2015 10:39 AM
Snort
Jul 9, 2015 03:58 PM
Jnkml
Jul 6, 2015 01:20 PM
