help with suspension issue?
Old Mar 25, 2007 | 09:06 AM
96Blurple's Avatar
So my friend has front coil-overs from his 4x4 '04 tundra that he had never used !! I need to now if I can install these on my 96 4x4 Tacoma with or without any problems!? also what rear shocks would be the right fit to match? my Ranchos are done do to the wheelin I've done !!so I need a new setup asap!!
Old Mar 25, 2007 | 09:16 AM
BajaRunner's Avatar
The top-plates will have a different diameter, so they will not work. If you take out your coilovers, and disassemble them (and the tundra coilovers too) you can swap the spring top-plates. They are the plate that has the three studs in them and fasten the coilover to the top mount.
Old Mar 25, 2007 | 09:37 AM
96Blurple's Avatar
Thanks....I think I'll have to go a different rought =-/!I dont have the tools to seperate the springs! I was hoping to save some money !
Old Mar 25, 2007 | 09:45 AM
96Blurple's Avatar
do you now anyone that might swap them ?
Old Mar 25, 2007 | 09:47 AM
HuskyRunner's Avatar
Any mechanic shop should be able to swapthe parts for you. Shouldn't cost much if you just take in the parts.
Old Mar 25, 2007 | 06:15 PM
mpavolka's Avatar
Yea its like $10-$15 to rent the spring compresssors. If they are actually coil-overs like Donahoe, Bilstien or Sway-away and not just oe style coils you are not going to be able to use the original equipment top plates. However you could modify the mounting plates on the frame to fit the slightly larger spacing.
Old Mar 26, 2007 | 02:57 AM
MTL_4runner's Avatar
If these are aftermarket coilovers you may not be able to use anything on them because the coil lenghts may be totally different than what you need. Most of those coilovers are adjustable so the length of the coil doesn't matter as much, just spring rate.
bigjstang
Jun 2, 2025 03:56 PM
DeathCougar
Apr 1, 2018 11:29 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
andrewtexas123
Jul 23, 2015 11:22 AM
Vargntucson
Jul 4, 2015 12:15 PM
