Help Just cleaned engine bay and it runs very rough now
Old Jun 7, 2007 | 10:31 AM
  #41
Tacotex's Avatar
Lil plug trick
Originally Posted by twitchee2
well im installing the new plugs today $3 from the dealer then hope fully its drivable then ill drive it to get codes. Its a PITA to pull the plugs when the socket i have deonst have that little rubber thing in the top
You can use a socket to break the plugs loose, then a 10-12" piece of rubber 3/8" fuel line to thread the plugs out/in. You can remove some material around the end of the tube to make the walls thinner and more pliable. I've been using the same piece of tubing since '93 or so. Anti-seize is your friend.
live4soccer7
Sep 3, 2015 12:29 PM
DacodaYota
Sep 2, 2015 02:13 PM
puddlepirate
Jun 30, 2015 05:08 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
2wdtundra
Jun 18, 2015 05:19 AM
