Help Just cleaned engine bay and it runs very rough now
#41
Lil plug trick
You can use a socket to break the plugs loose, then a 10-12" piece of rubber 3/8" fuel line to thread the plugs out/in. You can remove some material around the end of the tube to make the walls thinner and more pliable. I've been using the same piece of tubing since '93 or so. Anti-seize is your friend.
DacodaYota
Sep 2, 2015 02:13 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
