**HELP** Flat tire---can't get the flat off
Old Jan 26, 2005 | 06:57 AM
TacomaTRD's Avatar
FWIW
I wouldn't use a "plug," you should use a "plug patch" using a plug will just loosen over time and leak again. Back in the early 80's when I worked at a full service station the owner would not and did not carry plugs just for this reason, patch everything. They didn't have plug patches back then...
lee's Avatar
lee
yea, i was gonna ask if youve been rotating.. i do mine every 7500K or so.
Old Jan 26, 2005 | 07:29 AM
bradym239's Avatar
Originally Posted by TacomaTRD
FWIW
The life of the plug was about 13 hours. I used it to get home and then to the tire place for new tires.
Old Jan 26, 2005 | 07:38 AM
TacomaTRD's Avatar
Well just if you have to have "newer" tires fixed make sure to use the plug patch. I have personally seen them last over 40K miles on my wifes michealins that had <5K on them when we had to have one fixed...
edit
BTW Pats are going to kick butt on the Eagles...
Old Jan 26, 2005 | 07:49 AM
  #25
bradym239's Avatar
edit
I honestly appreciate the advice. It's strange. In almost 15 years of driving I've never really had a flat---other than a slow leak that somebody plugged. Apparently fate was trying to make up for overlooking me for those 15 years.
I truly hope that the Birds can at least hang. I don't have great expectations, but I just don't want to see them embarrassed. I will tell you this, though, the Eagles have a GREAT defense and may surprise you.
Old Jan 26, 2005 | 07:51 AM
  #26
TechWrench's Avatar
Glad you finally got it fixed, I have dealt with my share of 'stuck' wheels, but yours sounds like about the worst I've heard of. I agree with the above suggestions to remove all wheels, clean the contact areas, and apply anti-seize to the hub contact points. Also regular rotations help to minimize this problem.
Old Jan 26, 2005 | 09:08 AM
  #27
Citykid's Avatar
This happened on my ex's car. For the life of me I couldn't get the tire off. Long story short, I now carry a rubber malet in my truck. Two to three good whacks and it'll come right off. And if won't hurt the rim like a hammer would.
Old Jan 26, 2005 | 09:28 AM
  #28
bradym239's Avatar
Yeah, that's not a bad idea. I think there should be room in the tool cubby under the seat for a mallet to fit. I may do that just in case.
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
ktm192k
Sep 24, 2015 03:36 PM
