Help! Check engine light after type "O" mod
Old Nov 1, 2003 | 11:07 AM
george16's Avatar
My rig's check engine light came on after i installed the type "O" gasket on the throttle body. Any ideas on what's wrong with it? I rest the battery but it came back again after 10 miles of driving. Thanks.
George
Old Nov 1, 2003 | 12:34 PM
Dr. Zhivago's Avatar
Away
You have a vacuum leak. Check for proper orientation of the gasket, it only fits one way correctly. Check for proper torque of the bolts and nuts that hold the TB to the manifold.
Hope this helps.
G
Old Nov 1, 2003 | 01:50 PM
george16's Avatar
Thanks a lot.
George
Old Nov 1, 2003 | 02:11 PM
MTL_4runner's Avatar
Yep, what he said.
Definately a vacum leak there or wrong gasket orientation.
Old Nov 1, 2003 | 03:06 PM
Tacoma Dude's Avatar
So should the gasket just go straight on? Or should I try to help the seal with something - kind of like how you use the motor oil on the oil filter before you screw it on?
Old Nov 1, 2003 | 03:15 PM
george16's Avatar
The problem's solved. It was a vacuum leak due to one hose underneath the throttle body not being connected. I didn't see it when i reinstalled because it was directly underneath and i didn't disconnect it on purpose. It was disconnected when i was pulling out the throttle body. Here is a pic of the culprit.
Again, thanks a lot for all your help. Yotatech rocks!!!!
George
Old Nov 2, 2003 | 08:51 AM
3.4v6's Avatar
when i installed the O gasket my rpm's jumped about 500, and from past experiences with making my truck idle higher i got a check engine light , the high idle tripped a sensor and threw a CEL. when i installed my O gasket i just adjusted the throttle cable to lower my idle.
Old Nov 2, 2003 | 09:49 AM
midiwall's Avatar
I did the same thing... Twice.
Once on my truck when I installed a trottle body adapter two years ago (and didn't find it until Dr. Z spotted it in a picture - ALMOST A YEAR LATER!). Then it happened again - this time by accident - when I installed an O gasket on FunRunner's truck.
Old Nov 3, 2003 | 01:06 AM
ahhh.... so the first time you were just testing Dr. Z, right?
Old Nov 3, 2003 | 06:09 AM
midiwall's Avatar
Yeup Yeup Yeup.... That's my story and I'm sticking to it.
sonic concepts
Aug 16, 2025 03:13 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
Dr. Evil
Jun 7, 2002 09:19 AM
