Help with CD install...
Old May 28, 2002 | 01:34 PM
RTdawgs's Avatar
what do i need to do to install a new CD player and amp. ive installed an amp before, but never a new CD player. what i need to buy/do?
Old May 28, 2002 | 01:49 PM
what kind of cd player? specs? etc ?
Old May 28, 2002 | 02:23 PM
RTdawgs's Avatar
pioneer DEH-P6400
Old May 28, 2002 | 02:27 PM
dbui27's Avatar
I think the only real thing you need is the stock wiring harness kit. It plugs into your harness and you just connect w/the deck. It even comes w/the standard colors and it even had the labels for the wires. Makes installing stereos really easy and you don't need to cut the factory connector off.
dave
Old May 28, 2002 | 02:31 PM
RTdawgs's Avatar
is it a pain getting to the wiring harness though?
Old May 28, 2002 | 02:42 PM
Corey's Avatar
Co-Founder/Administrator
This article here might come in handy too.
Corey
Old May 28, 2002 | 03:15 PM
RTdawgs's Avatar
got it, thanks corey.
Old May 28, 2002 | 03:39 PM
BTOWN4RUNNER's Avatar
No, it is not hard at all to get to the wiring harness. It is in the back of the stereo. Also, for the amp, you will need some power cable, stereo wire, remote wire, and inline fuse and holder and various connectors. That should be about it, along with patience and time. Take your time and you will be thoroughly satisfied! Goodluck! :beaver:
-Ryan
Old May 28, 2002 | 08:12 PM
RTdawgs's Avatar
yeah i got me a 8 guage amp kit, but do i need to buy one of these CD install kits i keep seeing or what???
Old May 28, 2002 | 08:25 PM
MRael's Avatar
This is semi off-topic, but its a good example of what I'm wanting out of some of you folks: lets see some write ups of your stereo installations! Now when it comes to stereos there is room for many different examples and so its not like I'm looking for the one single ultimate perfect install. Borrow or use that digital camera of yours and send me what you got, along with your components and what the final result is like.
Heres a little pic from my upcoming write up of a dual-amp installation under the seats of a 1st gen. This pic is from before I cleaned up the hornets nest of loose wiring:
Old May 28, 2002 | 08:40 PM
No you don't need one of those cd install kits. All you need is that wiring harness. Very simple. Corey gave you the link to get you to the cd player and the harness is a snap to connect, colors + labels. Installing an amp is a harder task than a head unit. You said you can install the amp, so this should be no prob. It's your choice on how you want to connect the wiring. solder, crimps its up to you. Good luck.
Vince
Old May 29, 2002 | 08:09 AM
RTdawgs's Avatar
aight great, thanks vince
Old May 30, 2002 | 09:48 PM
thyron's Avatar
dont you also need a little cubby hole thing to make it so it will fit in the oversize stock deck hole. unless thats an oversize aftermarket deck.
Old May 31, 2002 | 04:40 AM
peterbilt's Avatar
Thron,
I've seen install kits that include a filler "pocket" for the space below the unit. I was wonder the same thing. The space is also a good place to mount gauges.
Pete
Old Jun 1, 2002 | 12:09 AM
thyron's Avatar
ya on my cd player i have a little cubby hole thing that has a latching door on it. before i put your deck in i just took the little bracket things off the sides off the stock deck and it holds the deck and the cubby together
Old Apr 6, 2003 | 10:53 AM
99runner's Avatar
where can i get a stock wiring harness kit?
Old Apr 6, 2003 | 11:03 AM
White SR5's Avatar
Stock wiring harness kit from a local car audio shop. Make sure it fits though before you leave. With the CD install kits, I'm all for them. The factory radio is double-DIN, and the DEH-P6400 is single-DIN, so unless you want to have an empty hole under your CD player, I'd say either fill it with a matching piece of plastic, or get the kit like I did. I ended up putting my EQ in the little slot under the radio. Looks nice.
Zach
Old Apr 6, 2003 | 11:25 AM
Cebby's Avatar
Genuine Toyota issue pocket for under radio (when installing a 1 DIN head in 2 DIN slot) - $6.50 at the Toyota dealer
Old Apr 6, 2003 | 12:11 PM
AznSky's Avatar
yea all I did was a cd wiring kit for toyotas which cost me like 6 bucks at Wal-mart. After that, it was all ghetto rigging with extension cords
Old Apr 6, 2003 | 01:37 PM
Bumpin' Yota's Avatar
One thing to note. When you are attaching the cd player's wires to the harness you just bought, it's best to soilder them together then use shrink wrap or electrical tape around each wire to insulate them. Once all the necessary wires are joined and insulated, use electrical tape again and cover everything making one big wire. At this point you can use loom or not for added protection - I haven't.
Steve
Skidmarcx
Jan 17, 2013 09:06 AM
Mihun
Oct 22, 2012 01:37 PM
ChefYota4x4
Oct 1, 2012 12:29 AM
rockchucker
12
Sep 16, 2012 09:18 PM
Wrenchinjoe
Feb 11, 2011 06:40 AM
