Ok, slight tire rub with the lo-pro's
Old Apr 6, 2003 | 01:37 PM
Firefyter-Emt's Avatar
Yep.. Guess it is time to call Roger Brown... I have gotten a slight rub today on a heavy off camber full lock turn.. Those low-profile bump stops pushed the 32's over the edge.. it is very minor, but I want room to spare.. However, it does show I got more droop.. I expect about 2"+ of suspension travel at the wheel.. (I hope)
BTW... If you have gone to the lower bump stops, unbolt the top of your shock, jack the truck to alow the tires to droop and see where your shocks sit.. I had to shim mine down about 1/4" to give it full use of the drop it now has.. Otherwise it would hang up on the shock..
Old Apr 6, 2003 | 01:53 PM
oly884's Avatar
Guest
I had some rubbing right after I got my lift on, it rubbed on the vailence panel so I just took that off and scrapped it. Any ways, if it isn't bad, take a rubber hammer and flaten the area that it rubs. I don't know where it does this on your truck, but it's worth a shot.
djpg2000
Nov 11, 2020 04:56 AM
chukarhunt
Dec 8, 2019 11:39 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
