Help! brake warning light on
Old Feb 23, 2005 | 04:24 PM
gunracer's Avatar
Unhappy Help! brake warning light on
Just replaced the left front caliper assy. on my 95 4rnr. bled the brakes using a one man bleeder assy/ bottle. all seemed well until I started it and stepped on the pedal. went to the floor and then pumped up and the brakes feel like normal but the brake warning light will not go out.. what to do next???
Old Feb 23, 2005 | 04:25 PM
Phssthpok's Avatar
Hate to say it.. you need to re-bleed.
Old Feb 23, 2005 | 04:31 PM
firemedic's Avatar
There are two sensors which activate the light (pretty sure):
1) Brake fluid level sensor- either level is low or sensor is stuck/defective
2) Parking brake sensor- activated when the handle is pulled, either it is defective or you need to check it is properly positioned
The other possibility is, if the alternator is on it's way out, it can cause havoc with the dash "idiot" lights.
Old Feb 23, 2005 | 04:56 PM
gunracer's Avatar
I think the problem is from letting the brake pedal come up with out closing off the bleeder valve.. what do Ya think?? should I bleed the whole system or just the wheel I worked on?/
Old Feb 23, 2005 | 04:59 PM
firemedic's Avatar
Shouldn't really have anything to do with the brake warning light, unless you did not refill the brake fluid reservoir.
Old Feb 23, 2005 | 05:25 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I had a 2nd gen that was very sensitive to the fluid level being right up to the line on the resorvoir... no less. The addition of about a teasponful past where it looked like it was full was about enough to extinguish the light. I heard the same from other 2nd gen owners. There are threads about it.
Old Feb 23, 2005 | 05:45 PM
dragon564's Avatar
Rebleed the entire system just to be safe...IMHO I will not drive anything that has a possible brake problem....that and Rick F has a very good point that sensor is very sensitive....firemedic is correct on the two items that can get that light to come on.....
Old Feb 23, 2005 | 06:49 PM
Robinhood150's Avatar
I think you've got two different problems.
1. not enough brake fluid causing the light
2. air in the system causing the pedal to fall to the floor.
Old Feb 23, 2005 | 07:14 PM
firemedic's Avatar
What he said...
Old Feb 23, 2005 | 11:00 PM
dragon564's Avatar
Update, I just went out to mine and made a point to check.....
with the e-brake pulled out the light comes on with the turn of the key
when the brake is in the light is off (DUH not trying to be a wise guy here)
When the fluid cap is off the light comes on
move the float up and the light goes out....
Note: on mine there was a sweet spot that will allow the light to come on but it was much dimmer than normal I would put it at about half btween the high and low lines.
I pulled the ALT belt and the light did not come on....
There you go.
fountain
Dec 31, 2015 06:08 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Odin
Jul 15, 2015 09:28 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
