Help: 96 4Runner won't stay running..
Old Jul 6, 2013 | 06:28 PM
baylai's Avatar
Question Help: 96 4Runner won't stay running..
We have a 1996 Toyota 4Runner 3.4L 4x2 that will not stay running. We put a new motor in it. When you spray gas into the throttle body, it will start up and die again unless you are continuously spraying gas into the throttle body. It has spark, so I am assuming something is wrong with the fuel system, I tested the fuel pressure and I am getting 58-60 PSI but it still won't do anything. So I put a new regular on it and a new EFI relay and still nothing. Suggestions?
Another question I have is, when I turn the key on, the fuel pump doesn't do anything. It only turns on while trying to crank. In the book it says to turn key on and I should have 33-44 PSI but it doesn't even turn on when you turn the key on, only while cranking. So could this be why it is not cranking?
PLEASE HELP!
Old Jul 6, 2013 | 06:45 PM
kball's Avatar
From what I know the pump should only be pumping once you are cranking. It does not prime. Are you sure you have all the sensors hooked up? MAF, Crank and Cam position sensors?
Edit: I don't know what book you have but the Toyota FSM says:
Attached Thumbnails Help: 96 4Runner won't stay running..-fuel-pump-when-cranking-running-only-fsm.jpg
Old Jul 7, 2013 | 08:01 AM
baylai's Avatar
Yes, all of the sensors are hooked up. I am thinking its the brain?
Old Jul 7, 2013 | 08:09 AM
kball's Avatar
Could be..? You say "new motor" what is it? Same year? Did you use donor motor sensors or originals?
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
hangtown88toy
Jul 10, 2015 02:33 PM
raiderhawks00
Jul 8, 2015 06:23 PM
