help 2000 rear pannel removal & electrical issues
Old Jan 31, 2010 | 04:51 PM
tommytuttle's Avatar
Ok.. long story short I've been having electrical issues, first rear tailgate power lock stopped working, now nothing works if the vehicle is not running.
I want to remove the rear pannel on the tailgate, I started to tonight but it is pretty cold out and i don't want to break any plastic.
Can anyone give advice on the removal?
any thoughts on what could be giving me the electrical grief.
it started with the cargo light only staying on for a couple of seconds after shutting off the vehicle, then the power lock on the tailgate, now no power locks on the vehicle until I start the engin, then it works??? is it a bad ground somwhere.. and if so.. where ????
it is below freezing right now so any ideas would be helpful before I go spend hours trying to figure this out.
Any assistance is appreciated.
Tommy
Old Jan 31, 2010 | 09:22 PM
SLOMatt's Avatar
The rear panel is pretty easy to remove. First use a flat-bladed screw driver to remove the plastic cover over the rope handle, then remove the 10mm bolt behind that cover.
There are a set of plastic fasteners along the bottom edge of the panel, these can be pried out using something like a plastic spatula. The panel "hangs" on a lip at the top near the bottom of the rear glass.
- Matt
Old Feb 1, 2010 | 06:43 AM
Thanks Matt.
Just like my 92 then.
I was starting to pry but got worried.
Old Mar 22, 2010 | 01:26 PM
Update: I found the problem with my vehicle
A bunch wires in the accordian type joint between the rear hatch and the body of the vehicle were broken, I guess the angle at which the door closes and opens puts too much stress on it all. Well with the help of a computer tech neighbour we neatly sodered it all together and all is well.
Old Mar 22, 2010 | 02:33 PM
Gerdo's Avatar
I had similar problems.
Take the plastic retainer off the rubber accordion and throw it away! The wires have not moved in the last few years since I took mine off.
This plastic piece causes the wires to break!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
