Heat wrap pipe on ISR mod??
Old Jul 30, 2003 | 09:12 AM
mycotopian's Avatar
My awesome wife who I always thought was just entertaining me when I showed her my tinkerings brought up a good point that deserves attention. Metal is a much better heat cunductor than plastic. Thus now when I touch the intake pipe its pretty damm hot which means the air inside is also pretty damm hot.
Since we are going for the every little bit counts here shouldn't we be getting these pipes coated to resist heat or use some of the heat wrap I see on headers to keep intake temps down???
Old Jul 30, 2003 | 09:21 AM
Churnd's Avatar
It would be a good idea. It wouldn't hurt anything, so why not? Every little bit helps. When the ISR mod first came out, I tried to think of a way to rig up some kind of intercooler that would wrap around the pipe, and voila... instant cold air intake. It started getting too expensive so I scratched the idea.
Here's the discussion I was talking about
Old Jul 30, 2003 | 09:33 AM
midiwall's Avatar
What a timely post!
I asked Dr. Z about these products JUST this morning:
http://www.speedzone24-7.com/cool-it.htm
http://www.speedzone24-7.com/exhaust-wrap.htm
(an alternate to the above)
http://www.speedzone24-7.com/Exhaust%20Jackets.htm
To paraphrase, he said that he used to use the stuff on his car, but given that it was a turbo, the engine compartment temps were much higher.
The products _do_ work though... In the case of the above, it's a question of how much do you want to pay to reduce the temp in the engine compartment.
Old Jul 30, 2003 | 09:36 AM
rimpainter.com's Avatar
Just because the ISR piping is hot does not mean that the incoming air is hot. Its the source the air is drawn from that really matters. The velocity of the air is too fast for the "hot" ISR mod piping to make a difference.
Ever seen an AEM cold air intake? The pipe is ceramic coated, but it draws air from the fender well. That's where the majority of HP gain comes from.
I wrapped the entire intake on my 98 3.4L, and it did nothing. I say don't bother.
Old Jul 30, 2003 | 11:27 AM
SLC Punk's Avatar
I agree, unless you have a turbo, its not really necessary.
Old Jul 30, 2003 | 11:39 AM
Churnd's Avatar
One trick you can do though... if you want a couple extra brief HP, get a couple of ziploc bags full of ice and stick them on the ISR pipe to get it nice and frosty cold. Go for a drive and be amazed, and then sulk when the power disappears. :cry:
Old Jul 30, 2003 | 07:39 PM
mycotopian's Avatar
in an atempt to make sure i am getting fresh cool air i used my hole saw and punched a 3 inch hole through my airbox and fender so i can route an intake from the front valence into the airbox. after a short drive i stuck my hand through the hole and into the airbox and it was HOT!! about as hot as having the heater on full blast . There has to be a way to get these temps down.
pickle6415
Apr 14, 2021 06:20 AM
punks_is_4x4
May 31, 2016 06:03 AM
87runner_
Sep 19, 2015 03:28 AM
larrys93pickup
Sep 17, 2015 07:05 PM
Boomer8404
Sep 10, 2015 09:01 AM
