Headlight Harness
Old Sep 1, 2003 | 07:05 AM
Cmar's Avatar
Question Headlight Harness
I did a bit of searching on the board about the upgrade headlight harness mod and I have a couple of questions.
For those of you that have the mod, is there REALLY that much difference?
Suvlights told me to go for the super heavy duty set for my dual battery set up.
When I spoke to an electrican, he said he couldn't see that it would improve light intensity by a significent amount.
So any input before I buy would be useful.
Suvlights quoted $65 for the harness and $12 for postage... Is this good?
Thanks
Old Sep 1, 2003 | 07:22 AM
Joe's Avatar
Joe
They will negotiate a little. I got 2 HD harnesses from them for $100 and that included freight. I also got their Osram Silverstar +50 Halogen bulbs. On my vehicles (Sequoia & Tundra) the HD harnesses did not make a difference to the human eye. I did notice a nice difference in light (distance remained the same) with the Osram bulbs over stock. If I had to do it over again I would just purchase the bulbs and forget about the harness.
Old Sep 1, 2003 | 01:12 PM
Churnd's Avatar
That's pretty high for the harness. I paid $50 shipped, but the company I bought from went out of business. If memory serves me right, I saw a voltage increase of 13.3 over 12.7v stock. The difference is there in the numbers. As for brighter light, it doese shine brighter... but not necessarily further. If you want distance, get some Hella 500's
Old Sep 1, 2003 | 01:21 PM
Cmar's Avatar
If I measure the voltage on the stock headlight wiring and then directly from the battery with the engine running I should see a difference then?
Old Sep 1, 2003 | 01:25 PM
Churnd's Avatar
You're saying:[list=1][*]Measure the stock harness[*]Measure the battery[/list=1]
...both while the engine is running???
If I'm understanding you correctly, then yes you will see a difference of about a volt.
Old Sep 1, 2003 | 01:31 PM
Cmar's Avatar
Correct Chris,
Will this show up as brighter light if I get the harness? I have Hella 550 fogs and soon will have 4x 55w Spotlights on the cargo rack on the roof. So do I really need it?
Old Sep 1, 2003 | 02:41 PM
Churnd's Avatar
If you're gonna have all that auxiliary lighting, then I'd say don't get it. Just upgrade your headlights and leave it at that. The only reason I got the harness is because I don't have aux lights and wanted the brightest light possible from the headlights.
Old Sep 1, 2003 | 03:30 PM
midiwall's Avatar
I agree with Chris. Given all that aux lighting, you don't really need the harness. Unless you just want the brightest light you can get out of your headlamps.
But, to answer your original question, I can definitely see a difference. My lights are back to white, when they were yellow. The biggest change for me is up on high beams which makes sense given the additional current demand.
I also moved up to a high output alternator around the same time, but I ran with just one harness in for about a month to verify that there's a difference.
Old Sep 2, 2003 | 03:44 AM
Cmar's Avatar
Thanks for the advise guys, much appreciated.
I would love HID's, but I am a little concerned about the quality of what is on offer, and I have standard glass headlights (not the multi reflective one's)
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
tshort48
Sep 27, 2015 01:04 PM
