Which headers are compatible with a 1" BL?
Old Aug 25, 2009 | 04:30 PM
xcmountain80's Avatar
Before you even start, the headers will be installed on a motor that is out of the vehicle so not so much a PIA. I just need to know which will work with my 1" wabfab BL. A SC is in the works and I feel a set of headers will compliment it.
Aaron
Old Aug 26, 2009 | 05:36 AM
Well I expected some response, but none? I have searched and nothing definitive has come up. I know some say no BL at all will fit while others say only with a 2" will you run into problems.
Aaron
Old Aug 26, 2009 | 06:06 AM
ScottyC's Avatar
Why would a body lift cause clearance issues? It gives you more clearance. So, if it will fit with no body lift then it will fit with a 1".
Old Aug 26, 2009 | 06:49 AM
There is an alleged issue with the steering linkage and the header coming into contact with one another. Most companies will tell you NO Way but have not evaluated the big 3 BL's (1",2",3")make certain at least not to my knowledge. I'm not 100% certain on the HP gain but figured if the engine is out I mine as weel seeing the SC will be on there too.
Aaron
Old Aug 26, 2009 | 07:13 AM
4Crawler's Avatar
1" is typically OK on the Tacomas and 3rd gen 4Runners:
- http://www.4crawler.com/4x4/ForSale/...l#Introduction
Old Aug 26, 2009 | 07:40 AM
Good information, now I need to figure out which will have the lower clearance, I'm guessing the eddlebrock headers are problematic, given the statement on 4Crawlers site. I got a quote on the TRD headers at $880 ouch....
Aaron
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
voiddweller
Sep 28, 2015 11:21 PM
toyotasaurus
Sep 24, 2015 03:30 PM
