Header
Old Sep 29, 2003 | 03:58 AM
Firsick's Avatar
Header
I have a question about Headers. I did a search but found nothing. I installed the Pacesetter header, Pacesetter Hi flow Cat,
Flowmaster Muffler, and a Pacesetter tip and now it wont idea correctlly. It idle's at about 200rpm's so I turned the idle screw up just to keep it running. Do you think I need to replace the O2 sensor or is it something I forgot to do.
Old Sep 29, 2003 | 04:36 AM
Cebby's Avatar
Does it keep stalling? Check the air hose connections between the AFM and TB.
Old Sep 29, 2003 | 04:40 AM
Firsick's Avatar
No it dosent stall at all it just runs at a very low RPM. I had to turn the idle up just to keep it running. I did not change tho O2
sensor and I tried to be very careful when I removed it and installed it in the new header but I still might of damaged it not sure.
Old Sep 29, 2003 | 06:21 AM
CTB's Avatar
CTB
Kind of sounds like there might be a vacuum leak somewhere.
Are all of the vacuum hoses in your engine bay hooked up?
Old Sep 29, 2003 | 06:50 AM
Firsick's Avatar
I will have to check on that. I didnt think about that. Thanks
TheBFA
Feb 15, 2020 06:55 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
voiddweller
Sep 28, 2015 11:21 PM
toyotasaurus
Sep 24, 2015 03:30 PM
DiggnDeep
Sep 3, 2015 02:45 PM
