Has anyone ever done custom made 5 grooves crankshaft on the 5vz-fe?
Old Sep 2, 2010 | 01:36 PM
4rx's Avatar
4rx
The reason I am asking you all this question because I am getting alternator belt slip every time I start engine. The 5vz-fe came with 3 grooves crankshaft. The alternator is too strong for 3 grooves pulley on the alternator. My alternator is a 270amps. It's for my stereo system that keep my electrical system strong. The 270amps alternator came with 5 grooves pulley but I changed it with stock 3 grooves pulley. The alt belt is new and tight. It has been like this ever since I installed a new alternator. I always ignored it. It's getting on my nerve now.
I might don't get much help from here but I give it a shot.
Old Sep 2, 2010 | 01:38 PM
xxxtreme22r's Avatar
maybe try a different brand of belt?
Old Sep 3, 2010 | 10:55 PM
4rx's Avatar
4rx
Yeah someone suggested me about the gates belt.
Old Sep 4, 2010 | 03:26 AM
gates or a GoodYear gaterback if they make them for the 5vz. I would try that route first since it's the cheapest.
Old Sep 4, 2010 | 06:36 AM
akaphilly's Avatar
URD makes a "supergrip" pulley... not 5 rib tho. just sayin
Old Sep 8, 2010 | 10:35 PM
4rx's Avatar
4rx
Thanks for telling me about URD but dam to expensive $99.00. They also make crankshaft but is $299.00. Forget it.
I'm gonna try belt first.
Old Sep 8, 2010 | 10:59 PM
7m4x4dude's Avatar
have you tried a stock yota belt? i actually have had bad luck with the two belt's sugested at less then 100amp on supra 3rib set up's.
oh btw what altenator are you running to achive 270amp's?
the only one i knew about was the mr2 100amp eletric power steering model.. as far as stock altenators go..
Old Sep 9, 2010 | 01:09 PM
4rx's Avatar
4rx
I think I threw away the old one.
There are few companies that can make 200-300 amps alternator(i've seen upward to 400amps). Look up Iraggi Alternators, DC Power Engineering, Mechman, Ohio Gen, and Powermasters.
Old Sep 11, 2010 | 04:44 AM
pkt1213's Avatar
I know they make the gatorback belt for it. Been running one for about 3 or 4 years now.
jasonty
41
Dec 23, 2018 01:00 PM
priest16
15
Aug 6, 2015 07:43 AM
kirkrunner
Jul 27, 2015 07:59 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
