Gears?
Old Jul 4, 2005 | 03:04 PM
Lone4runner's Avatar
Gears?
Trying to understand how to buy my gears for my front and rear differentials. Guess first question is the number. upgraded Ex:4.10:1 if i had say 3.97:1 wpuld this be a better combination? like does the higher the number give you more tourque? and the smaller gives you better hp and acceleration. and the next question would be where would i buy them from? i want to eventually have 33's tires on a 3rd gen limited 4Runner. I just want to be able to off roadf better with bigger tires but also want ti understand how the gearings work. also last thing is how it would effect a locker since i hope to change the rear diff as well as the front to ??? Sorry for the extyened post but please help.
Old Jul 4, 2005 | 03:13 PM
kyle_22r's Avatar
the rule with gears is, the higher numerically they are, the more torque they'll give you. of course, it's a trade-off between acceleration(higher number) and top speed(lower numbered gears). on most toyotas, you won't have to worry about top speed
for 33s on that, you might want to get 4.56 gears. on a V6 runner, this will put your power and speedometer to about stock with bigger tires. since its a 4x4, you'll need to regear both the front and rear, otherwise things could get messy.
for installation, you'll want to have a shop or somebody experienced do the gear setup. you'd want to put in a locker at this time -- saves money.
Old Jul 4, 2005 | 03:58 PM
rocket's Avatar
Lots of good info here: https://www.yotatech.com/forums/f116/33s-4-88-5-29-gears-60566/
Gear ratios, differentials, lockers, indentification, etc...
http://www.brian894x4.com/Gearratiosanddiffs.html
http://www.off-road.com/toyota/tech/other/4_axles.html
hope that helps!
Old Jul 4, 2005 | 06:08 PM
thanks you guys
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
