Gauge and dash backlighting
Old Oct 7, 2009 | 06:25 AM
  #301
fireball's Avatar
Guys, quick question regarding the bulbs in my 99 4runner.
Can you replace the bulbs in the top row of the center console, the "Rear Defrost" ECT and back window up/down switch? I took that piece apart last night and it looks like those bulbs are soldered to the circuit board. For some reason mine are all out. The Rear Defrost little orange light illuminates when the button is depressed, but when you turn on the interior lights there is no backlighting for those other buttons.
Any help would be appreciated!
Old Nov 3, 2009 | 07:53 AM
  #302
SuperSixOne's Avatar
Originally Posted by 3w41d
Gauge lights:
96-98: #194
99-02: #24
/thread
My 02 took 74's not 24's. 24's were to large and 74's fit perfect.
Old Nov 3, 2009 | 11:42 AM
  #303
3w41d's Avatar
well then you're just weird
thats strange though..other 02"s i've seen are #24's
Old Nov 28, 2009 | 05:06 PM
  #304
dwnhiller93's Avatar
running to radio shack here in a minute.. How many and what kind of LED's do I need?
Old Nov 28, 2009 | 10:55 PM
  #305
txt4r's Avatar
I have the same problem.
Any idea/experience? Any one?
Old Dec 2, 2009 | 05:36 PM
  #306
MaK92-4RnR's Avatar
Ok, I've read just about every single LED conversion thread. and everyone's done a 3rd gen write up and product list. but how come no one has done a required list for a 2nd gen 4runner? does anyone know what bulbs are needed and how many are needed for the SR5 gauges, dome lights, cig lighter, climate controls, power windows, and everything else? I've decided to tackle this and a list of bulbs would make things amazingly easier
Old Dec 17, 2009 | 01:06 PM
  #307
bak3rme's Avatar
i have a 1999 4runner sr5. i just need to know how many i need in the guage area. not so interested in blinkers or anything. just main bulbs.
also if u know how many i need for a 1999 sr5 then i would appriciate it very much~!
Old Dec 17, 2009 | 01:38 PM
  #308
bak3rme's Avatar
where can i get #24 bulbs? i looked on website but they dont say #24 bulbs
Old Dec 18, 2009 | 11:55 AM
  #309
3w41d's Avatar
what website did you look on
http://www.v-leds.com/24-74-NEO-LED/...orLanding/true
Old Jan 1, 2010 | 02:10 PM
  #310
AlexJet's Avatar
Arrow
Originally Posted by bootown
mike here's what I come up with for my '02 Limited:
Shifter: 74
Digital Climate Control: 2 - neowedge type A (3mm), 2 - type B (4mm)
Defrost/ECT: neowedge type A
Rear window: neowedge type A
Ash Tray: 74
Key Ring: 74
Map Lights: 2 - Ba9
Domes: 2 - Festoons
Glove box: 74
Vanity: 2 - 31mm fuse bulb
Not positive on the following but pretty sure:
Gauge Illumination: 3 - 24's
4WD: 3 - neowedge Type B
All other gauge lights: 74's
Blinkers: 2 - 74
A note on the digital climate control: There are one (probably two) lights that I didn't try to get to. They are most likely soldered. One light is the fresh/recycle air button and I believe there is another similar button on the upper right. Maybe this summer I'll get to it. Just a warning if you don't have soldering experience replacing the DCC if you screw up is quite expensive. Problem is the fresh/recycle button is always on so it will probably be annoying if everything else is a different color.
Power window, security, passenger seatbelt are all soldered.
I think that covers everything. Thank you everyone that contributed to this thread!!!!
I recently bought 2001 Limited for my wife and mention that I have only gauge claster and AutoClimateControl light up when lights are on. This evening my left part of AuotClimateControl gone "dark". This is last call for doing something.
I want to replace the central console lights as I only have right portion of AutoClimateControl on and nothing else, absolutely nothing else.
Reading all thread up I think I might need 5-6 #74, 2 Neo Type A and 2 Neo Type B. Would it be enough for all central console and glove box?
As mentioned in the second quote, what to do with circuit board lights? I didn't opened mine, but when I would, I'll be better prepared.
Please advise if my calculations are right, so i can order... Thank you.
Old Jan 1, 2010 | 07:19 PM
  #311
sportrunner2001's Avatar
So I am thinking of doing this and everybody here keeps on saying the same thing leaving out the stereo. How would one be able to change those or would it be better to spend more money and buy a new stereo deck with blue backlights?
Old Jan 16, 2010 | 11:35 AM
  #312
AppRunner's Avatar
How did you do this? I have a 99 sport and i've tried the 194 (to big) and the 75 (to small). I want my dash to look just like this, but i can't find the #24 led's you were talking about in one of your posts. I gave up and went with some glow gauges. I hate them cause they look like some punk ricer ride. I'm trying to go with the white gauges and i want it to look stock. Please tell me how you did this.
Old Jan 16, 2010 | 11:38 AM
  #313
AppRunner's Avatar
k, forget about what i just posted. guess i didn't read far enough into this thread. gave up a couple pages to soon
Old Jan 16, 2010 | 02:10 PM
  #314
AlexJet's Avatar
Autolumination has them.
Old Jan 16, 2010 | 03:28 PM
  #315
AlexJet's Avatar
How to get to the shifter bulb? Where is it?
P.S. I found that "Seat Warmers" type switches has 2 NeoWedge Type A bulbs on the side.
UPDATE: Those switches do have bulbs inside, but Toyota wiring (at least on my '01 Limited) does not have light wire to power them in harness.
Old Jan 18, 2010 | 05:25 AM
  #316
bak3rme's Avatar
amen, im with this guy , please help us '99 on what to buy and how many, we would appreicate your help. I've searched fourms and all i got were the '00 and up bulbs, but ppl say that the '00 models and up have different specs. and the 98' and lower have different specs, so the 99's are stuck somewhere in between, i have an sr5 . this guy has a sport edition . SOS
Old Jan 18, 2010 | 07:52 AM
  #317
bak3rme's Avatar
radio shack has these bulbs? led style?
Old Jan 26, 2010 | 07:06 PM
  #318
bak3rme's Avatar
bump for a 1999 sr5 2wd shopping list
Old Jan 26, 2010 | 09:58 PM
  #319
kernel's Avatar
Another 99 here. I just installed an Alpine deck w/ blue illumination. I'm doing this either way so maybe I'll be the guinea pig for the rest of you 99ers. Should be happening within the next couple weeks when I have time to rip the dash apart and get proper styles and numbers. Stay tuned...
Old Jan 27, 2010 | 04:54 AM
  #320
bak3rme's Avatar
man what model do u have the sr5 or limited? i wish u wouldnt of been the guiene pig, coz we could throw down or shipping together. then mail it either way. but anyways if u got sr5 hit me up with the shopping list
