Fuel Pump or Not?
Old Feb 3, 2005 | 08:37 AM
Maverick's Avatar
Fuel Pump or Not?
Ok, all what do you think about this...
I was sitting in my truck, 92 4x4 with 155,000, 2.4L, at the gas station when it just quit running. I had just filled up the tank with gas and was sitting there idling, and it just quit running. I tried to start it again and found that the efi fuse was blown, I replaced it, and it blew another one. I tried jumping the efi relay by jumping B+ and FP in the digonistics terminal, recomemded by a friend to see if the relay was bad, and it still blew the efi fuse. It acted like it wanted to start and then the fuse blew. Is it the pump or something else. How hard is it to change a pump out, and what should I expect along the way. Thanks in advance.
Maverick
Old Feb 4, 2005 | 03:34 AM
Maverick's Avatar
someone has to know something....!
Old Feb 4, 2005 | 07:17 AM
eric-the-red's Avatar
Could be the pump, could also be a wiring short somewhere. They can be lots of fun to track down. Try taking a piece of wire, with an inline fuse on it, from the positive battery terminal to the FP terminal in the diagnostic box. That'll bypass the EFI relay and fuse, may narrow down the search. If that fuse goes than the problem is in the pump or wiring to the pump.
You have to drop the tank to change the pump, it's inside. Before you do that I would check the wiring under the truck for broken insulation.
Old Feb 4, 2005 | 03:51 PM
Maverick's Avatar
Thanks very much, seems like a lot of people don't know too much on this topic, or else they don't care to comment. I apprecitate it though. I'm tearing into it tomorrow. Thanks again
Maverick
Old Feb 4, 2005 | 03:55 PM
epic37311's Avatar
Really don't know. If its blowing the fuse its grounding out somewhere. Did you try the search function on this forum? When somethings been coverd several times people just stop posting about it after a while.
Old Feb 4, 2005 | 04:04 PM
epic37311's Avatar
Here ya go
https://www.yotatech.com/forums/show...ight=fuel+pump
Old Feb 4, 2005 | 04:13 PM
epic37311's Avatar
LOL it was coverd 4 days ago.
Old Feb 4, 2005 | 04:19 PM
DMG's Avatar
DMG
Another tech I know just fixed this problem on a 92. It was the PCM but don't replace it until you check it further. The EFI fuse goes to a lot of things. Get a bunch of fuses (or a circuit braker and 2 male spade terminals) and a schematic. Unplug one possible cause and see if the fuse blows. Keep doing this til you narrow it down.
DMG
Old Feb 13, 2005 | 11:14 AM
Maverick's Avatar
Thanks everyone, I got it fixed, I had to bench test the pump, it didn't work, Thanks again
Mave
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
