fuel injector and rear diff.
Old Jan 30, 2004 | 10:09 PM
jethro's Avatar
ok i went to jiffy lube to get my oil changed and have them check it out since I hit the 60,000 mark not too long ago. The guy said to get my fuel injector and rear diff. done, which isnt too much $. Then he started telling me how it would increase my horsepower and things like that. Wondering if you guys had any input on this.
Old Jan 31, 2004 | 01:36 AM
Mossback74's Avatar
Re: fuel injector and rear diff.
Hope this isnt your first oil change
Personally, Jiffy Lube and all like it suck.
To do their "Fuel System Cleaning Service" yourself :
1. Search for MAF/Throttle body cleaning, follow instructions.
2. Buy Techron injector cleaner, follow instructions
3. Give me (And Bob_SR5) a dollar
4. Go to step 3
To change your Rear Diff:
1. Buy gear lube, See you manual for weights 75-90 works fine,
2. Change Fluid
3. Give me a dollar
4. Go to step 3
In my opinion, when you go to placed like this for service you get screwed, and they dont use lube.
Old Jan 31, 2004 | 05:30 AM
MTL_4runner's Avatar
Don't use jiffy spooge or anything like it!!!
Do it yourself and you'll know it was done right.
Follow Mossback74's info except there is a typo on line 3....it sould be given to MTL_4runner.
Other than that they are great instructions.
Old Feb 2, 2004 | 01:13 PM
jethro's Avatar
Well, I'm not that good at working with a car, thats why I use Jiffy Lube. Is it going to hurt anything to let them do it?
Old Jun 23, 2004 | 04:34 PM
FORANA's Avatar
Dude there are all kinds of morons out there. They are everywhere even at Jiffy Spooge. Not going to let them touch my "Huney". Oil change is about as easy as taking a dump. Check the maintance section in this forum for instructions.
Greggie ppoo
Old Jun 25, 2004 | 07:15 AM
havic's Avatar
The only problem with doing your own oil change is that the oil filter is hard to get to. I do it mself during the warmer months, but in the winter I take it to a shop. Everything else is easy. Any easier ways to get to the oil filter? I have a 98 4Runner 3.4L. Thanks.
Old Jun 25, 2004 | 10:24 AM
FORANA's Avatar
Really? I don't have any trouble getting out my filter. You gotta go through the driver side wheel well. Checkout the tech writeup section in this forum for detailed instructions on how to do it. Really, its easy as taking a dump.
Old Jun 26, 2004 | 02:50 AM
Mossback74's Avatar
If you're having problems with the filter (most do) there are relocation kits available.
Here's one from PP
Amsoil Filter/Bypass kits are even better
Old Jun 26, 2004 | 02:57 AM
Mossback74's Avatar
For an even better injector clean try seafoam
This Thread has all the info
Old Jun 26, 2004 | 04:46 AM
bamachem's Avatar
Do your runner a favor and look at this thread too.
https://www.yotatech.com/forums/showthread.php?t=35112
$15-$18 to clean the intake, mass air flow sensor, and injectors. Another ~$15 will get some good Mobil 1 Gear Lube in the rear differential. If you have a 4WD, do the transfer case and front differential as well. There's also a write-up in the tech section on how to FLUSH your transmission yourself - something that most dealers charge $150+ for.
jbv808
Aug 6, 2021 04:47 PM
sandyota
Feb 4, 2021 11:16 AM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
karbin
Jul 5, 2015 11:37 PM
