Fuel Gauge goes to E when I stop
Old Dec 22, 2008 | 08:23 PM
atistang's Avatar
I just filled my tank, after driving about 30 miles i came to a stop light and glanced down at my fuel gauge. It was going down from full to empty at a rapid pace. It went all the way down to empty, then when i took off from the light and started driving again it went back up to just under full. It has done this every time i stop all day. The only thing i can figure is there is a dead spot in the sending unit right under a full tank.
anyone have any other ideas or have had a similar problem?
03 taco 3.4, I just did the gray wire mod, but i did that the day after i bought the truck so i don't know if it did this before or not.
Old Dec 22, 2008 | 08:40 PM
aaron26889's Avatar
i had a car that did that and it was just a bad floater thing that says how much gas is left in the vehicle.
Old Dec 22, 2008 | 08:45 PM
thedude42's Avatar
hmmm i have never had a problem like that except one day when i was out on a trail i was climbing up a hill in my runner and my gas light came on i think the floater just rolled to the very back of the tank (i was on a really steep incline) once i levelled out it went back up
Old Dec 23, 2008 | 07:14 AM
EnolaGaia's Avatar
Both your stoplight / brake light and your fuel sender circuits use the 'BN7' connector (which should be underneath or in the close vicinity of your driver's seat). A fault or short in the wiring at that point might explain the behavior - causing the fuel sender to lose 'signal' when the brake is applied.
Your fuel sender's ground point is behind your left kick panel (brown wires) - you might want to check that, too.
Old Dec 23, 2008 | 07:23 AM
atistang's Avatar
ok, thanks, i'll have to stop and pull the parking brake and see if it happens or not, actually that is where i grounded my gray wire for mod. maybe after we get through this ice storm i'll undo it and see if the problem stops
Old Dec 25, 2008 | 05:37 AM
atistang's Avatar
I'm thinking its a dead spot, once it got under 3/4 of a tank it stopped happening
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
gary4runner
Sep 24, 2015 12:53 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
