Fog Lights or Driving Lights.... That is the question
Old Jan 7, 2003 | 08:58 AM
nags's Avatar
Well.. I want to install some extra lights on the front of my new tacoma, but I'm not sure if I should install some driving lights or fog lights? What would benefit me the most? This will be for street driving,.. Not off roading... I would like something that'll fit into the whole in the bumper.. I have about 2" to work with top to bottom and about 6" wide..
Thanks,
nags
Old Jan 7, 2003 | 09:10 AM
BTOWN4RUNNER's Avatar
In my opinion, you definitely want to go with a fog light. The driving lights are great, but are basically high beams that allow you to look wayyyy ahead of where you are going. Fog lights are designed to penetrate fog, rain, snow, sleet, hail, dust, dirt, bugs, birds, well...you see where I am going. They are very cool. I have PIAA 520 fogs and love them. They will not fit into your opening, because they are like 7" round or so. But the whole idea of a fog light is a good thing. You would be absolutely surpised at the difference that they make. They cut right through everything. I sometimes, in very bad fog and rain, drive w/o my headlights on at all and just use the fog lights, that is how good they work. Check around and see what you can find, but I definitely recommend fog lights over driving. :fireman:
Old Jan 7, 2003 | 09:11 AM
UKMyers's Avatar
Nags welcome to Yotatech!! I see you made it over from the Darkside.. This place is much more friendly and generally more active as well. Anyways I have both fogs and driving lights on mine and I find I use my fogs alot more often. We have tons of traffic here where I mostly drive at night so I don't use my highbeams hardly ever. The fogs fill that void from the front of your truck to the bottom edge of your lowbeams. It all depends on your driving I guess. They are both nice. Someone posted the other day about installing some Hella Optilux lights that were fogs and driving lights both with a 3 position switch. That might be an option.
Here's the thread
Good Luck! Well done on posting a pic on your first post.. You will fit right in here...
Old Jan 7, 2003 | 09:13 AM
WATRD's Avatar
Well then, the question is, what do you hope to use them for?
If you do a lot of night driving, on deserted back country roads where your headlights don't even make a dent in the darkness, driving lights are key. They have a long throw that pierces the darkness ahead of you and helps keep you from "over driving" your headlights, that is driving such that if something where to appear at the edge of the light envelope, you would not be able to stop in time.
If your driving is mostly on curves or around town, throwing hundreds of watts of power half a mile out in front of you is pointless. The light will be hitting other cars/drivers/curves not much beyond what your headlights can do. In that case, a nice set of wide dispersion fog lamps are handy. Fogs will throw quite a bit of light ahead, but their real forte is filling in the deadspots between, around and to the sides of where the headlight beams are.
Driving lights == high speeds or long distance
Fog lamps == better lighting close in and much better peripheral vision.
Old Jan 7, 2003 | 09:15 AM
Corey's Avatar
Co-Founder/Administrator
Hello Nags, and welcome to the forum.
Normally I'd recommend the Hella 500s I run (see my website in the mods section) but since you have not decided yet on fog or driving, how about both
Lightforce is an Aussie company that makes real nice lights.
They come in three sizes, and all can be fitted with a yellow lenses turning them into a fog light.
Todd has the 140s on his rig.
http://www.pnw4runners.net/~todd/misc/
They are the smallest out of the three.
You can see his yellow lences here.
He has the gray 1st gen 4Runner.
http://www.pnw4runners.net/~todd/Gre...2/DSCF0001.JPG
If I replace my 500s on my bumper, I'll probably get the Lightforce 170s.
Old Jan 7, 2003 | 09:23 AM
WATRD's Avatar
Um, Corey? It's not the color that makes it a fog lamp, it's the beam pattern.
Although fog lamps are traditionally amber because it tends to cut through moisture in the air, an amber cover over a driving light is still a driving light
Aren't the Lightforce lights refocussable too?
Wide, shallow beam == fog lamp
Long, pencil like beam == driving light
Color is irrelevant, a nice amber is a plus on fog lamps, but fog lamps can be white too...
Old Jan 7, 2003 | 09:41 AM
jacksonpt's Avatar
Senior Member
I've got a decent set of Pilot driving lights that might fit the space you're talking about. They are a 55w bulb, driving lamp. Not bad, not great. I run a ton of lights on my rig... and from my experience, the best way to increase your visiblity is with some 100w euro beams. but they are waaaay to big for your application. Your next best bet would be to find some fog lights that fit your space, then swap the 35w bulb out for a 55w bulb.
Here's a pic of my lamps... the ones on either side of the license plate. If memory serves, they are about 6" long by 1.75" high.
Old Jan 7, 2003 | 09:46 AM
Corey's Avatar
Exactly. You can focus the beam pattern on them, I just left that out.
Most relate fog lamps to an amber colored lens though.
But with the Hella's like I have, they do change the lens fluting to make it a fog lamp, and color.
Corey
Old Jan 7, 2003 | 10:14 AM
nags's Avatar
Here's the thread
Thanks for all the help so far. I've definetley recived a lot more information here already than the "other" board. As for posting pics.... if you check out some of the other boards that I frequent you'll see that I'm quite the post whore.. I know what I'm doing
Thanks everyone for the info so far.. I haven't had a chance to read through the whole thread cuz I'm at work right now, but I'll be sure to go through it all when I get back home.
Thanks again,
nags
Old Jan 7, 2003 | 06:50 PM
nags's Avatar
Anyone got pics of lights installed on tacoma's?
Old Jan 7, 2003 | 07:15 PM
WATRD's Avatar
My website has pictures of my PIAA 520's mounted on a brush guard in the first life of my Tacoma and then the same lights on my ARB as it looks now. http://www.watrd.com
If you visit the WATTORA site, there are several of the members rigs that have various lights mounted in various ways. Look in the past events section and the members section for pics. http://www.wattora.com
Old Jan 7, 2003 | 07:30 PM
nags's Avatar
thanks. I'm really hoping for someone to post some pics of lights installed that I like and then I can just buy the same ones
I'm lazy
Old Jan 7, 2003 | 07:44 PM
WATRD's Avatar
No problem. I hope someone posts something that "speaks" to you
Here's a few culled from our members pics;
http://www.wattora.com/pastevents/20010729/DonnaMar's%20Pictures/donnamar_DCP_1154.jpg
http://www.wattora.com/pastevents/20020609/P6090031.JPG
http://www.wattora.com/pastevents/20...3Sultan205.jpg
http://www.wattora.com/pastevents/20020223/02230205.jpg
http://www.wattora.com/pastevents/20011124/DCP_1456.jpg
Old Jan 7, 2003 | 07:45 PM
nags's Avatar
Thanks, but I dont have a brush guard, so most of those are out :cry:
Old Jan 7, 2003 | 07:50 PM
WATRD's Avatar
Ah well, I tried
Best of luck with it
Old Jan 8, 2003 | 01:16 AM
Bundubasher's Avatar
Hi guys
I use the rectangular Hella 550 Fog Lamps (I think they are 35W but I'm not sure) and they throw a white beam LOW and WIDE. Much wider than dipped lights and I find this very helpful on medium/narrow country lanes. The only problem is that I've pendant mounted them under my ARB Bullbar and they do not lie parallel with the road - they are slightly higher on the outer edge - but in the foggy conditions we get here in the UK they are pretty damn essential as spots are useless.
Anyroad, that's my two pennies worth...
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
