Fog lights
Old Dec 3, 2002 | 11:59 AM
sharpshine's Avatar
Question Fog lights
I just bought my first 4Runner last week (SR5 2000) and was wanting to get some fog lights for it right away. Living in San Francisco Bay Area they are a life saver.
I noticed that on the front bumper there is a space with small round false covers. Is this for fog lights or just decoration? Is there a better placement area and what is the best set up (product) for my 4Runner? Is OEM in this case the way to go?
Sharpshine
Old Dec 3, 2002 | 12:13 PM
Bob K's Avatar
I too am looking at putting some on mine. The Toyota lights are $262.00 and that comes with everything. Hella also makes a set Micro DE www.performanceproducts.com that are $199.00. I am not sure which way I am going yet.
Hope that help.
Old Dec 3, 2002 | 12:45 PM
jalaber's Avatar
Just to be clear, the Toyota kit you are referring to is the Hella DE kit and it is a dealer installed item that can be purchased anytime. The true OEM kit is made by Stanley and costs $720 for just 2 lamps and 2 brackets. Most of the wiring is already in place and all you would need is the Toyota stalk w/ fog switch and plug in relay (and big $$$).
Old Dec 3, 2002 | 01:22 PM
Bob K's Avatar
I was at the dealer last Wed and they had information on fog lights for the 4Runner to fit in the factory mounts. They were advertised as Toyota factory lights $262 for the complete kit. The guy at the parts counter did not indicate they were made by Hella, he said they were Toyota.
Old Dec 3, 2002 | 01:54 PM
Jason B's Avatar
Welcome to the board.
http://community.webshots.com/user/starnrg
Old Dec 3, 2002 | 04:33 PM
LSUMatt1514's Avatar
You would definitely be better off to try and fit some aftermarket fogs into the stock opening rather than buying them new from the dealer. I recently tried to find a replacement Stanley fog light because of a cracked lens and the dealer wanted about $350 for one lamp. I ended up getting one at a salvage yard here in B'ham for about $100. Several people on here have retrofit some Piaa fogs into the stock openings, I believe. Hopefully they will reply here.
Matt
Old Dec 4, 2002 | 03:19 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I recently bought and installed the Toyota OEM fog light kit for my 2000 SR5 which is the Hella Micro DE's for ~ $200.00. They install in the small, round openings next to the parking lights in the front bumper. Installation is per the instructions and took me about 1 1/2 hours (pretty good, considering I had never removed any parts of the dash before). Everything you need is in the kit. Other than bolting the brackets on, bolting the lamps to the brackets and plugging the lamps into the existing harness, the wiring under the dash and steering column required some dash and steering column cover removal which took the most time.
I'm very happy with the lamps. I will, however, change the wiring sometime since the fogs will only work when the headlights are on low beam when wired per the instructions. The stock, H3 bulbs are 55 watt. You can upgrade to 100 watt bulbs, but I personally am hesitant with concerns of heat damage.
There are a lot of aftermarket fog lights that have gotten excellent reviews from others in the forum.
Old Dec 4, 2002 | 08:16 AM
Bob K's Avatar
Where does the the switch for the lights go?
Old Dec 4, 2002 | 08:27 AM
Rick F.'s Avatar
The switch for the lights that came with the kit I discussed above goes in one of the blank openings in the left side of the dash. My 2000 has 3 blanks, if I recall. They pop out very easy as the blank is spring loaded. The switch that came with the kit was an exact fit. Unfortunately, it is unlit. I suppose you could get the Toyota lighted switch, p/n 00550-35976, separately.
Old Dec 4, 2002 | 08:28 AM
INsr5runner's Avatar
I have the Hella Fog's on my 2000, and it was the first mod I did. It was very simple, and a great get-to-know-your-truck-mod. I mounted my switch just below where the factory switch would have been. I opted for the lazy way, and didn't get a Toyota switch. It's out of the way, and doesn't bother me any so oh well! I think it took me only about 1 1/2 hours too, most of the time was trying to make sure the lights ligned up perfectly in the slots, so no gaps would be showing.
If you decide to go with the Toyota switch, you just pop out the existing plug, and in it goes!
Old Dec 4, 2002 | 09:33 AM
jalaber's Avatar
Or for a really factory finish, you can get a new toyota stalk with fog lamp switch. Do a search for price and part #. Looks great and saves a cut-out for other stuff.
Old Dec 4, 2002 | 06:28 PM
gadamiii's Avatar
Fog Lights
I was thinking of adding some Hella Micro DE fog lights to my 2000 SR5. Do I need to order from Performance Products to insure that I get the right mounting brackets, or are the brackets already installed? Thanks.
Old Dec 4, 2002 | 09:19 PM
sharpshine's Avatar
Out of the Fog
Thanks to everyone for their respone to my interest in fog lights. The Toyota dealer near my house has the Hella Micro DE for $250 but I have checked around and have found them for as low a $199. But I am going to take a closer look at what Piaa has to offer. Does anyone have part #'s or model #'s of the Piaa lights that will work in that space?
Old Dec 5, 2002 | 03:22 AM
Rick F.'s Avatar
There currently is a thread on this forum regarding the Hella Micro DE's. You can get the OEM Toyota kit which has the Hella Micro DE's, brackets, relay, switch, wiring, etc.. I don't have the p/n handy that I ordered for my 2000 SR5, but I was able to get the kit on-line for $199 + s&h. I'm not positive if the PP kit is identical to the Toyota OEM kit.
Old Dec 5, 2002 | 04:44 AM
trdtacoma01's Avatar
Could these Toyota fog lights from late model 4Runners(next to the parking lights) fit a Tacoma....since for some reason a $26,000 Tacoma doesnt come wit fogs and a $13,000 Mazda B series does
Old Dec 5, 2002 | 07:09 AM
gadamiii's Avatar
Thanks. The reason I ask is because I found a Hella Micro DE kit for about $135, but I wasn't sure if I needed to buy the brackets as well, which would eventually cost the same as the PP kit.
Old Dec 9, 2002 | 10:10 AM
gadamiii's Avatar
Sorry everyone, I replied to the wrong thread...
Old Dec 10, 2002 | 11:18 AM
Hella Fogs on Ebay
hey don't know if you still are looking for lights, but I saw these on Ebay today...
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
