Flat spots on accelleration in 2nd.....
Old Jul 21, 2004 | 07:28 PM
Bumpin' Yota's Avatar
Full throttle accelleration 0-70mph.
1st gear runs through pretty damn quick without problems. Tranny shifts quite quickly into 2nd and the rpm goes from 5600 rpm from 1st to 2800 or so in 2nd.
In 2nd gear the rpms slowly climb to ~3300rpm and then drops to ~3150rpm, then continues climbing unabated.
This is all at full throttle, gas pedal stuck to the floor....
torque converter acting stupid or fuel delivery problem?
Old Jul 21, 2004 | 07:32 PM
AgRunner06's Avatar
My first thought is that it's a fuel problem. I'd check the adjustment on the TPS and replace the fuel filter if it hasn't been done. Other tune-up stuff may be in order if it hasn't been done in a while.
That's all I can think of.
Old Jul 22, 2004 | 10:50 AM
Did the plugs, wires, cap, rotor, and ignition wire about 500 miles ago OEM of course. The flat spot got much better but is still there. Replaced the old fuel filter at ~230,000 miles, so about 21,000 miles ago.
TPS aye? hmmm....
If not the TPS, and not the ignition, it would have to be fuel delivery then right? Could a faulty injector do this somehow?
Also, as my engine IS older than dirt, I likely have a lot of carbon build up inside it. Could that cause this too? (If so, it's getting motor vacc'ed soon.)
Old Jul 22, 2004 | 10:56 AM
rimpainter.com's Avatar
Sounds like tranny slippage to me. Smell the AT dipstick and see if it smells burnt.
Old Jul 22, 2004 | 10:59 AM
az4x4runner's Avatar
Wouldn't the RPM increase if it was tranny slippage?
Old Jul 22, 2004 | 11:13 AM
What I mean is a slip and then a bog as he described.
Old Jul 22, 2004 | 11:41 AM
hmmmmmmmmmmm
Out of curiosity, what friction plate does the 2nd gen tranny use for reverse?
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
