Fitting Magnaflow Muffler with 2.5" I/O to OEM Pipe Question
Old May 4, 2010 | 08:48 AM
Swede's Avatar
I got the Magnaflow 22" - 5"x11" muffler (P/N 12586 http://www.magnaflow.com/02product/s...e=main&id=8448 ) which has the 2.5" I/O pipe, and my question is, will I be able to slip the OEM pipe, which I think is 2.25", inside the muffler pipe and just clamp it down or do I need to get some kind of adapter? Thanks.
Old May 4, 2010 | 09:51 AM
MaK92-4RnR's Avatar
I wouldn't clamp exhaust, it leaks like a SoB. but if you have 2.25 piping, and the muffler is 2.50, it should slide on fairly easy, but i'd weld it.
Old May 4, 2010 | 09:57 AM
kiyobrown's Avatar
x2. If you don't have a welder, it shouldn't cost you more then $50 from an exhaust shop to have it welded up if you are supplying the muffler and you don't need new pipe bent.
Old May 4, 2010 | 10:17 AM
okie81's Avatar
Yes, and If you're gonna pay a muffler shop weld it up, you might as well spend another $50-100 and have them bend 2.5 all the way out.
Old May 4, 2010 | 10:20 AM
kiyobrown's Avatar
Good call, good call.
But there goes the whole idea of fixing the exhaust for cheap, right?
Old May 4, 2010 | 02:13 PM
Elton's Avatar
yea 2.5'' will be fine if ur supercharged
Old May 4, 2010 | 02:16 PM
Swede's Avatar
Well I'm not SC'd so I can't see it making any difference. I guess what I'm asking is will a clamp compress the 2.5" pipe enough to create a good seal over the stock pipe. Thanks for the input though.
Old May 4, 2010 | 02:27 PM
Elton's Avatar
have it welded on exhaust leaks are annoying
Old May 4, 2010 | 02:31 PM
2DoorRunner's Avatar
x100,000,002
Weld it.
Old May 4, 2010 | 02:44 PM
NwRunner's Avatar
Weld it.
This is my 2.5 magnaflow on my 2.25 stock pipe
Old May 4, 2010 | 03:13 PM
kiyobrown's Avatar
After that pic, I say clamp PROBABLY won't work, lol. You would have to grab some reducers, and extra clamps.
Or weld it.
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
hexrain
Jul 12, 2015 01:13 PM
Cplmike
Jul 8, 2015 08:47 PM
