Field Monitor Unit - 98 4Runner
Old Oct 8, 2009 | 11:40 AM
Rock Slide's Avatar
Originally Posted by ESQ
Rockslide:
Actually, mounting the the T sensor in free stream won't give a colder reading than ambient. It will read ambient. Heat may be lost more quickly in fast air, but the temperature of the sensor will bottom out at ambient unless it is wet (then you'll get evapourative undercooling) or it is in sun (radiant heating giving a higher reading).
ESQ, very true!
Forgive my ignorance as I posted that informaton 2yrs ago....when I was young and dumb . I have since learned how these sensors operate.
Old Nov 29, 2009 | 04:40 AM
blcktpgsr's Avatar
i hope to own one of these units
Old Dec 20, 2009 | 12:09 PM
Mrbikerman's Avatar
Originally Posted by Rock Slide
Just remember, try not to mount this temp sensor in a spot that gets hit with direct air flow from the outside. For example, if you drive on the freeway at a high rate of speed and it's already cold outside, the temp sensor will be hit with a constant strong force of air. Thus causing the temp readings to state it's colder outside than it really is. This air will be much colder than the air if around your vehicle if you were parked.
This is not true, temp gauges are not affected by wind otherwise there would be no need for the "windchill factor" scale. Wind only affects things that produce their own heat.
Old Dec 20, 2009 | 12:51 PM
Rock Slide's Avatar
Exactly. Read my response a couple posts up...
Old Dec 20, 2009 | 12:54 PM
  #25
Ritzy4Runner's Avatar
If you mount them where the factory mounts them which is just below the left head light on the front metal radiator support sheet metal it will not be in any direct air flow no mater how hot or cold it is outside so you will get a more true reading. Here is how I did it quote from above.
"Update: Installed the temp sensor behind the left front bumper below the head light. Was super easy. Removed the canister that is located in the left front fender well exposing prime location for the Temp Sensor. Used existing hole to to act as the alignment tab for the sensor. Marked a hole location and drilled it out. Placed sensor on the front side of the fender well, bolt, lockwasher, nut and then wired the plug with the sensor wires I routed through the firewall and zip tied to the existing lighting wire run."
Old Jan 4, 2013 | 10:51 AM
  #26
hrt4me's Avatar
Originally Posted by Ritzy4Runner
If you mount them where the factory mounts them, which is just below the left headlight on the front metal radiator support sheet metal, then it will not be in any direct air flow, no matter how hot or cold it is outside, so you will get a more true reading. Here is how I did it - quote from above:
"Update: Installed the temp sensor behind the left front bumper below the headlight. Was super easy. Removed the canister that is located in the left front fender well, exposing prime location for the Temp Sensor. Used existing hole to to act as the alignment tab for the sensor. Marked a hole location and drilled it out. Placed sensor on the front side of the fender well, bolt, lock washer, nut, and then wired the plug with the sensor wires I routed through the firewall and zip tied to the existing lighting wire run."
thanks for the handy instructions
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Doug4320
Mar 24, 2018 10:11 PM
mskalmus
May 28, 2017 07:51 AM
gary4runner
Sep 24, 2015 12:53 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
