Fabtech 6 "
Old Feb 2, 2004 | 10:08 PM
LT_Z's Avatar
Fabtech 6 "
Anyone have the 96+ tacoma 6" on a 3rd gen 4Runner ? I am looking into this and im wondering if I have to buy the complete kit or If i can get the front end. It was suggested to get the all pro leaf kit for the rear. Is there anyway to cross refrence some coils for a 6 " ? thanx in advance !
Old Feb 3, 2004 | 12:05 AM
dbikeman's Avatar
To get 6" out of the rear you would need new rear linkages that were longer. The linkages are too short for that much I think
Old Feb 3, 2004 | 03:14 AM
Breezey's Avatar
Guest
Re: Fabtech 6 "
Feel free to check out my site: www.toy4runner.com I have all of the install pics of the rear lift.
Fabtech only sells the complete kit. the rear kit has blocks anyways, so just ebay them or something. Also you will need the Pro Comp extended brake lines.
another way you can lift your truck is buying a Pro Comp Tacoma front kit only and then do all pro for the back or somethign else. I hope this helps.
Old Feb 3, 2004 | 05:30 PM
LT_Z's Avatar
I think I will just do the Fabtech cuz I like their quality a little better than procomp. But Where do I get the All pro leaf kit ? I will look into the brake lines as well thanx ! !! Oh what will this let me clear ? 35's ? 33's ?
Old Feb 3, 2004 | 05:34 PM
Breezey's Avatar
Guest
you should be able to clear 35's with your fabtech lift and the all pro kit. www.allprooffroad.com tell them Greg from toy4runner.com refered you. they will set you up. order the 4" leaf spring kit and i think it will give you enough lift in the back... 4+ shackles is about 6" total
Old Feb 3, 2004 | 05:47 PM
LT_Z's Avatar
With the 4" + shacles will the ride be even or the back higher ? also can i use the downey spacers with the 6 " coils ?
Old Feb 3, 2004 | 05:51 PM
Breezey's Avatar
Guest
downey spacers with your stock suspension in the rear will not be high enough.. only way to do it keeping your rear suspension, is having all custom linkage made for teh height you want.
Old Feb 3, 2004 | 10:28 PM
LT_Z's Avatar
Hey Breez on those pics of your rig with the IFS stuff how many inches is that ? and what size tires ? Oh what i ment was can i use the Fabtech & Downey spacers for the front = 9" & get the correct kit from all pro to even the rear ? what ya think ?
Old Feb 4, 2004 | 10:44 AM
Breezey's Avatar
Guest
You cant stack the Fabtech lift with the downey lift. I already looked into that. If your looking for a good IFS lift, get the fabtech kit.
offroadross1985
Aug 11, 2005 04:28 PM
keoua1
Apr 8, 2005 11:08 AM
baileymoto
Mar 22, 2004 08:28 PM
Darx
Oct 25, 2003 09:02 AM
