Extend Both Diff Breathers?
Old Mar 15, 2008 | 07:47 PM
Quattro15's Avatar
I've read that it's good to extend both diff breathers and also that you only need to really do the rear breather.
What is the correct answer on this one? It seems relatively easy to do once you get the part number for that breather extension bit that the hose mounts to.
I am rarely in deep water, I would have to say extremely rarely. I do hit some nasty puddles though! Our road systems don't lend to great drainage at all! Is it even worth me doing this to my truck?
Also, where is the optimal place to put the breather once extended?
Thanks!
Old Mar 15, 2008 | 07:51 PM
wjwerdna's Avatar
OMG search!!! lol
I put mine behind gas tank fill door as in numerous write ups, I never got to the front, but I have the parts to
Puddles don't matter, your truck was engineered to at least work on the street, splashes are okay, submersion is not
Old Mar 15, 2008 | 08:08 PM
edzo's Avatar
you don't need an extended breather for the occasional puddle
you only need one if you expect to be in water long enough to cool
the diff and suck water in. if you just dip the diff now and then not a big deal
I ain't saying -no chance-...rather, -low risk-
at least with my 99 4runner, I go and get wet and submerge now and then for about 20 feet at
a time and have never had any junk inside my diff as a result. axle bearings, now
that is another matter
if you have roads that get flooded and you drive in them for more than a 1/20th mile then yes I would plan ahead and extend the breather
Old Mar 15, 2008 | 10:25 PM
Dare44's Avatar
so what happens when u guys get stuck in the 20ft ur crossing haha
Old Mar 15, 2008 | 10:33 PM
89silverpu's Avatar
You don't need to get a special part just some tubing and hose clamps: https://www.yotatech.com/forums/f116...ension-139986/
Old Mar 15, 2008 | 11:15 PM
Scooby098's Avatar
well you need some pipe fittings for the hose, and I just reused the diff breather for the top with the hose clamp
Old Mar 15, 2008 | 11:47 PM
89silverpu's Avatar
just put the tubing over the stock diff breather with the cap removed...
Old Mar 16, 2008 | 04:56 AM
Belize Off Road Team's Avatar
i used medical tubes. i finished the extesion about 1 week ago:
Old Mar 16, 2008 | 06:40 AM
edzo's Avatar
well, right.
if you know the hole, u r ok
if there is a chance you'll get stuck, dump the toyota breather
and run a long hose
live4soccer7
May 11, 2016 06:52 PM
primordialbeast117
Dec 19, 2015 12:23 PM
kcaudill
Oct 10, 2015 02:39 PM
kbpickens
Oct 2, 2015 03:37 PM
Odin
Sep 26, 2015 06:56 PM
