Exhaust Tips
Old Jun 7, 2004 | 02:55 PM
venice4504's Avatar
Exhaust Tips
Ok- So on my 2002 i have the normal exhaust tip that comes out the right side. I am a little jelous of the 2003+ exhaust tips that are chromed and come out the back. I was wondering if anyone knows if the Valor exhaust tips that Toyota sells will fit a 2002 runner. I am not looking to change where the exhaust comes from, I just like the finished look of the chromed tip. Thanks for any help.
Old Jun 7, 2004 | 05:01 PM
terky's Avatar
as long as its the same size. i dunno on stock cars but aftermarket exhaust is all welded together. take it to an exhaust shop and they can do it in like 5 min for a few $.
Old Jun 7, 2004 | 08:40 PM
TechWrench's Avatar
Before you change the exhaust tip to exit the rear, do a search on the sulphur exhaust smell many 4th gen owners are having. Many of those who have the problem tend to blame it on the position of the exhaust tip. It seems that the air flow in the rear of the vehicle can cause the exhaust to be sucked into the cabin if you like to leave the rear window open. Some have claimed to fix the problem by installing new exhaust pipes that change the final pipe to aim either down or to the side to avoid the air flow problem. If you do try one, try to get one that can be easily removed or changed back if the results are not good.
Zach_trun
Jan 22, 2020 04:42 PM
Yont283
Sep 20, 2015 10:56 PM
Yont283
Sep 12, 2015 10:03 AM
idadan208
Sep 7, 2015 09:06 AM
