Engine Problems, need help!
Old Jun 1, 2004 | 11:15 AM
Praufet's Avatar
Ok so when I start my car it starts of idling about 1500 then after it warms up the idle drops to 750 or so and idles roughly to where I can feel the vibration in the car. Other times it will start idling a hair over 1k and then goto idling roughly? :wtf: Any thoughts?
Old Jun 1, 2004 | 11:17 AM
4RUNR's Avatar
Guest
Check the timing.
Old Jun 1, 2004 | 04:06 PM
Praufet's Avatar
how do I check it?
Old Jun 1, 2004 | 04:11 PM
My99's Avatar
If you haven't messed with the timing, and it just all of a sudden started doing this, then it shouldn't be that. Tell us more. When did it start? Does it do it all the time? Sounds like a plug/wire problem to me. If you rev it up does it still miss?
Old Jun 1, 2004 | 04:18 PM
bike4miles's Avatar
Yea, I would check your plugs and wires. It is likely that one cylindar is missing so I would just do a basic tune up with cap rotor, plugs, and wires if needed.
Old Jun 1, 2004 | 05:23 PM
Praufet's Avatar
Well I just got a new(used) engine, and the guy didn't touch the dist. He replaced caps, rotors, plugs, and wires.
Old Jun 1, 2004 | 05:48 PM
Gadget's Avatar
You might also want to do a compression check.
Gadget
Old Jun 1, 2004 | 06:11 PM
MTL_4runner's Avatar
Gadget
Compression will verify the mechanicals and spark and fuel are the only other possibilities. Now mind you there are various components that make up the systems but those are the areas to focus on if the compression is ok. Should be around 170 psi + and within 10% of each other.
Old Jun 1, 2004 | 08:13 PM
nigeltufnel3's Avatar
Arrow
ok, well I know about the least of anyone here, but I would second the plugs, cap, rotor, wires, etc. The difference between aftermarket stuff and Toyota (Denso) parts is amazing. Also, here's a real shot in the dark, but it may be a thermostat issue. Maybe reset the computer. One last idea would be to clean your throttle body. I had my idle around 750 RPM and I cleaned my throttle body and it shot up to over 2 grand, just cause it was 'breathing' better. Again, I'm am no sort of expert, so listen to those other guys first, but I though I'd just give a couple ideas.
Old Mar 30, 2005 | 07:23 PM
alanbobalan's Avatar
i'm having similar issues with my truck. resetting the computer and cleaning my throttle body sounds interesting. how might i go about doing this? even if it doesn't solve the problem, it probably won't hurt anything would it?
Old Mar 30, 2005 | 07:51 PM
LS1Steve's Avatar
it is most likely the timing. have it checked/adjusted if necessary. resetting the computer won't do anything, the computer learns slowly and makes adjustments, so if the same problem lasts a few days, it won't help.
Old Mar 30, 2005 | 08:42 PM
i already had my timing checked and adjusted. what about cleaning the throttle body? would that help?
steve miller
Oct 10, 2015 01:40 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
