Engine oil for 3.0?
Old Mar 29, 2004 | 06:19 PM
KING's Avatar
Engine oil for 3.0?
How many quarts of oil do you put into your 3.0??
If I can read correctly, the manual says 4.8 QTs??
Either way, the new oil is so clear that I am having a hard trouble seeing it on the dipstick to adjust it.
I put five quarts in.
Need a fast answer, please.
Old Mar 29, 2004 | 06:30 PM
AgRunner06's Avatar
I always put in 5 quarts. That seems to be just right.
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
When I had my '90 with the 3.0, it would take 5 1/4 to 5 1/2 quarts (with filter change). I'd put 5 qts in then run the engine for a minute or two and then top it off after it sat for 5-10 minutes.
Scofco's Avatar
My Haynes manual says 3 to 4. Nothing specific.
Go by what the owner manual says.
Old Mar 29, 2004 | 06:38 PM
KING's Avatar
I put five in right now.
With sun light tomorrow, I'll double check and make any adjustments if need be.
I do remember putting 5.5 the last time but it seems too much.
Old Mar 29, 2004 | 06:50 PM
CTB's Avatar
CTB
I do exactly the same. I put in 5 qts (if the filter has been changed), then start it up and run it for a minute. Then, I check for the proper level. I usually put somewhere from 5.25 - 5.5 qts in.
Old Mar 29, 2004 | 06:51 PM
CTB's Avatar
CTB
3-4 qts of oil is definitely not enough (at least for the V6).
Old Mar 29, 2004 | 07:25 PM
Firefyter-Emt's Avatar
4.75 is right on the money for me.. That is one of the things I like about my Wrangler.. 4 quarts.. Yep, I bought one of those gallon jugs (I only need one!) High end stuff for that baby too, I got a gallon for like $5.75 at the parts store the other day... but it has 185k on it and runs better than the 4Runner has in the last 2 years.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Colington
Mar 8, 2020 09:51 AM
Roger Borba II
Jul 9, 2015 05:05 PM
