Engine cuts out at full throttle
Old Apr 21, 2013 | 11:59 AM
gm4runner's Avatar
Exclamation Engine cuts out at full throttle
hey i have a 1996 4runner with the 3.4 5VZFE and the 5spd manual trans. the car has been cutting out at full throttle, but if i ease of the gas a little i can redline the motor if i want(not that i do). when i give it full throttle the car will actually cut the rpms down to 3500 and acts as if its being governed AND I CAN ALSO SMELL FUEL WHEN THIS HAPPENS.the car has 550,000 miles on it, but this motor only has about 180,000 if that. any help is appreciated.
Old Apr 21, 2013 | 12:55 PM
rworegon's Avatar
So, don't stomp on it or redline it and the problem is solved, right?
Old Apr 21, 2013 | 01:40 PM
gm4runner's Avatar
i don t stomp on it haha if you gradually increse to full throttle the same thing happens, and i cant redline the motor currently either....thats the problem. SO, yes i guess that would solve it, but i want to fix it fully. BUT technically no, it doesnt solve anything.
Old Apr 21, 2013 | 02:18 PM
rworegon's Avatar
What have you done to troubleshoot the issue?
What is the recent maintenace history?
Is there a vacuum leak in the intake tube or any other vacuum line?
When was the MAF last cleaned?
Last timing belt change?
Air filter clean?
You could have a bad and/or partially plugged injector that holds the engine back when you are calling for lots of power.
Old Apr 21, 2013 | 03:08 PM
gm4runner's Avatar
Air filter clean?
oh boy where do i start haha, to try and trouble shoot i replaced the plugs and wires, fuel filter, cat w/ 02 sensor, i even replaced the mass air flow, TP sensor, ECT Sensor, and the fuel pump was done about 2 years ago. i have NOT done a timing belt yet, air filter was recently changed, and how can i test the injectors?
Old Apr 22, 2013 | 03:52 AM
Texas_Ace's Avatar
I would do a seafoam treatment, more just because it can't hurt then I think it will actually fix it.
Now load up the gas tank with injector cleaner, that could do some good for the issue at hand.
Do you have any CEL's?
A video of the problem would help.
Old Apr 22, 2013 | 07:11 AM
gm4runner's Avatar
i have run seafaom through the pcv valve already,and it made a differenece in power, but the problem still persisits. i will try seafoam as an injector cleaner too, but No CEL, and i will post a vid of it soon. Thanks
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
