Engine check light: P0171
Old Oct 7, 2004 | 12:32 PM
Unhappy99's Avatar
The visible bulby thing on the MAF module is NOT the MAF, it is the IAT (intake air temp sensor). The MAF hotwires (there are 2) are located deep inside the MAF tube thingy.
https://www.yotatech.com/attachment....achmentid=1361
https://www.yotatech.com/attachment....achmentid=1362
I've been using Carb cleaner on mine quite successfully.
Old Oct 7, 2004 | 12:59 PM
WATRD's Avatar
Here's what the Factory Service Manual has to say;
P0171
(DI–193)
System too Lean (Fuel Trim)
 Air induction system
 Injector blockage
 Mass air flow meter
 Engine coolant temp. sensor
 Fuel pressure
 Gas leak on exhaust system
 Open or short in A/F sensor (Bank 1 sensor 1) circuit
 A/F sensor (bank 1 sensor 1)
 ECM
CIRCUIT DESCRIPTION
Fuel trim is related to the feedback compensation value, not to the basic injection time. Fuel trim includes short–term fuel trim and long–term fuel trim.
Short–term fuel trim is the short–term fuel compensation used to maintain the air–fuel ratio at its ideal theoretical value. The signal from the A/F sensor is approximately proportional to the existing air–fuel ratio, and ECM compares it with the ideal theoretical value, the ECM reduces fuel volume immediately if the air–fuel ratio is RICH and increases fuel volume if it is LEAN. Long–term fuel trim compensates for the deviation from the central value of the short–term fuel trim stored by each engine tolerance, and the deviation from the central value due to the passage of time and changes of environment.
If both the short–term fuel trim and long–term fuel trim exceed a certain value, it is detected as a malfunction and the MIL lights up.
HINT:
 When the DTC P0171 is recorded, the actual air–fuel ratio is on the lean side. When DTC P0172 is recorded, the actual air–fuel ratio is on the rich side.
 If the vehicle runs out of fuel, the air–fuel ratio is lean and DTC P0171 is recorded. The MIL then comes on.
 If the total of the short–term fuel trim value and long–term fuel trim value is within ± 35 % (80°C (176°F) or more), the system is functioning normally.
 The A/F sensor (bank 1 sensor 1) output voltage and the short–term fuel trim value can be read using the OBD II scan tool or TOYOTA hand–held tester.
 The ECM controls the voltage of the terminals AF1+ and AF1– of the ECM to the fixed voltage. Therefore it is impossible to confirm the A/F sensor output voltage without OBD II scan tool or TOYOTA hand–held tester.
Old Oct 7, 2004 | 09:02 PM
Nam's Avatar
Nam
Unhappy99::
Oh no...I did not clean the right thing...so there definitely a hope for this! thanks so much for the pics...they're surely worth 2000 words. I will clean that thing tomorrow afternoon and see how it goes.
WATRD:: thanks for the desc. it's a great way to get started.
Nam
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
razorman8669
Jul 12, 2015 12:13 PM
