electrical problems! ACK
Old Nov 25, 2002 | 01:05 PM
r2xj's Avatar
Question electrical problems! ACK
OK, when i looked at my 94 4runner before buying, none of the lights on the inside worked, nor the radio. The dealer (not a toyota dealer, jsut aused car dealer) took a look at it, the fuse the radio was on kept poping, they said the switch to my lights just above the rearview mirror was fried and that was what was causing the short, so the un plugged it somewhere they said, and replaced the radio, cuz i guess that was shot too. Anyway, i was thinking about trying to fix it, but it would be a long process that would include pulling the ceiling pannels down or whatever... i was wondering if anyone else had a problem similar to this, or if they had taken those pannels off and what it would take. strange thing is, the rear light, the one back by the back tailgate door still works.
also, just last weekend, my rear window stopped going up with the key, if i get in and turn my car on, the inside switch works up and down, but with the key, it will only go down. at first i thought it might have something to do with the cold, but it was real warm here the other day and i tried it and it still doesnt work... and help on these topics would be greatly appreciated.
thanx,
rory
Old Nov 27, 2002 | 11:25 AM
r2xj's Avatar
thanx for nothin guys! just kidding, without you i wouldnt have done the cool blue signal lights while i had everything torn apart i thought you guys might wanna see how much of my car i had torn apart...
Old Nov 27, 2002 | 11:41 AM
Corey's Avatar
Co-Founder/Administrator
Dang, you really tore into that dash
Sorry, I don't have the answers for your electrical stuff.
Sounds like a lot of work.
Old Nov 27, 2002 | 11:58 AM
UKMyers's Avatar
Wow you did tear into that thing. I have had mine close to that once or twice in my gauge escapades. Gotta do it partially again tomorow. So did you ever get your problem fixed that you originally started out to do?
Old Nov 27, 2002 | 12:18 PM
r2xj's Avatar
yeah, all my interior dome lights and the cargo light works now drop out kid mechanic from the dealer, reversed some wires and had something shorted (took me 4 hours to figure it all out with out a handy volt-ohmeter)
Today i get to crack open my tailgate door and figure out why i t wont roll up with the key... any help on that topic would still be appreciated
Old Nov 27, 2002 | 12:26 PM
Corey's Avatar
I have some rear window scans here I did from my factory service manual several months ago.
http://www.pnw4runners.net/tech/rear_window_2nd_gen/
Corey
Old Nov 27, 2002 | 12:33 PM
r2xj's Avatar
OOO! muchas gracias corey! wow, i dont know how in depth my problem is, but however deep its is, this will help greatly! thanx once again!
Old Nov 27, 2002 | 07:37 PM
mtnfreak's Avatar
Re: window problem
I think I can help you with the window problem. It's got to be either the key switch or the wiring. The wiring is easy to get to, so find where it comes out of the tailgate & into the body. Peel back the protective covering(s) and examine the wires. Some less than reputable dealers and mechanics have been known to cut a wire or partialy cut one so that it will corrode and break a few months later. This can also happen on its own if the wires weren't wrapped up tightly. If that isn't the problem, dig into the tailgate and check out the switch. Make sure all of the connections are tight. Remove the switch if possible and clean thouroughly. Put a multi-meter on it and see if all of the contacts are made with the key in the different positions. Good luck.
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
