Electrical Lock Problem on 99 4runner
So i've been working on my runner an ran into a minor but annoying snag which might be the solution to another problem that i have.
So the problem i have is that i can not control my door lock switch's when the truck is off. they seem to have lost power..
But they do work when i put my key into the ignition an turn it to the on position and they work just fine.
So am thinking that the problem might be a burnt relay, but not entirely sure more like 60% sure.
Has anyone had a problem like this? Or know the location for the power lock relay?
I've never had this problem but here is a link to the complete wiring manual...hope it helps!
http://www.ncttora.com/fsm/1996/SIL/fsm/wiring.html
Okay well thanks i'll go threw it to see if anything catches my eye to what it might be.
The only reason i think it might be a relay is because ive seen other mods where they bypass the relay for the lighter so it can countiniously have power with out the truck being on.
Figured something like that might work, if i cant fix it
2002, 4runner, 60, 99, electrical, forerunner, lock, loses, malfunction, power, prob, problem, problems, relay, relays
