E locker?
Old Mar 10, 2007 | 09:11 PM
4low's Avatar
E locker?
Hey guys, I've done a search through the page but haven't found exactly what I'm looking for... I have a 99 4Runner and I've sourced out a 02 TRD Taco that has been written off. I what to grab the rear locker out of this thing. So my question is: how do I go about doing this? what part off the Taco am I going to need? will it swap over without have to cut or weld anything.....and do I need the tranny or front gears or anything?
As much detail as you can give my on this subject would be awsome. I'm not too mechanically inclined(I'll have someone else install all this stuff) so simple person talk would be nice too!! thanx people!
Matt
Old Mar 10, 2007 | 09:14 PM
Elton's Avatar
welcome to yotatech your in for some work https://www.yotatech.com/forums/f31/e-locker-build-up-99419/ use to be real good now the pics are gone not sure what gears you have and what the taco has
Old Mar 10, 2007 | 09:21 PM
d0ubledown's Avatar
you'll need just the 3rd. check the paint on the end of the pinion gear and someone here can match the colour with the proper gear ratio. if its the same as your current setup, you wont have to regear. if its different, you'll have to regear either the elocker to match the front, or the front to match the elocker. you'll also need the wiring harness that comes off the motor (not absolutely needed, but definitely makes wiring it up alot easier, and oem correct of course).
have a look at this page everything you've wanted to know about swapping in an elocked 3rd but were afraid to ask is all on there my friend..
good luck!
Old Mar 10, 2007 | 11:50 PM
bob200587's Avatar
you could just get the third...but the whole axle would make things easier...
Old Mar 11, 2007 | 12:14 AM
d0ubledown's Avatar
the whole taco axle would require new spring perches & shock mounts
Old Mar 11, 2007 | 06:50 AM
jrallan26's Avatar
Buy this truck and you should have all the parts...
https://www.yotatech.com/forums/f180/wrecked-2001-taco-trd-4x4-auto-no-motor-tranny-oklahoma-108805/
Then part out what you dont want....
I just read it was sold. Bummer...
Old Mar 11, 2007 | 10:57 AM
4low's Avatar
Awsome! Thanx guys. I'm gonna do some research and I'll get back when the project starts.
Old Mar 11, 2007 | 11:09 PM
4low's Avatar
Okay, I didn't know that Toyota made 4Runners with a factory diff lock option! would it be an easier proposition for me to sourse out a 4runner rear axle w/ a locker than going for the TRD taco diff? I'm thinking it would.
Old Mar 11, 2007 | 11:31 PM
DeathCougar's Avatar
Get the 4Runner rear axle/diff, which is an 8" diff. The tacomas use an 8.4" rear diffy, and are leaf sprung.
Old Mar 12, 2007 | 07:46 AM
BruceTS's Avatar
Wow, you actually got something wrong, the e-lockers in either 4Runners or Tacos have 8" diffs. There was never an 8.4" e-locker......
As for axles the Taco axle won't fit under the 4Runner, different design, only the third member, after a bit of housing modification.
There are plenty of threads
on this subject, surprised you didn't find much....
What other parts you will need is the switch to activate the locker, the e-locker ECU(under the drivers side kick panel) and wiring harness(located under the driver side floor trim)
Old Mar 12, 2007 | 05:30 PM
4low's Avatar
it's not that I didn't find much it's just that I found threads with so much crap to read through that it got all garbled.....I'm basically looking for a step by step how to type thing. You guys have been a hell of a help and I'd like to thank all of you that have lended your advice.
One more thing.....I have to change my ECU!! holy crap.....should I just go ARB? lol
So basically....the rear diff out of a Elocked 4runner, ECU out of a Elocked 4runner, the switch to activate this little sucker, and the wiring harness(I'm assuming the harness is just for the Elocker....not the whole damn truck right?)
Again, sorry for all the Questions, I'm just new to Toyota's. This is my first one. So far I'm loving it, it's just screaming to be locked up though.
Old Mar 12, 2007 | 05:33 PM
Curse you BruceTS lol. I realized that at work today....I went "Wait, no, thats not correct" but it was too late lol. But, at least I was right about the coil spring/leaf spring setup heh.
Old Mar 12, 2007 | 05:34 PM
garrett1478's Avatar
http://www.sonoransteel.com/phong/re...ic_locker.html
READ.
Old Mar 12, 2007 | 09:10 PM
4low's Avatar
cheers!
Old Mar 12, 2007 | 09:25 PM
d0ubledown's Avatar
most guys i know that retrofitted their 'E' didnt use the ECU. just throw in a couple relays, a DPDT switch, a bit-o-wire here n there..n youre good to go. The ecu just monitors the wheelspeed & tcase to enable the safety features doesnt it?
Old Mar 13, 2007 | 05:52 AM
4low's Avatar
Oh yeah......interesting. I also read in that link that Gerret gave me there(btw man thanx! that is exactly what I was looking for) that "downey" make's a manuel cable control upgrade for Toyota elockers....this may just be the way to go for me. I don't really like like push button 4x4 so between a push button and manuel locker......I like the later. I'm going to look into this option further.
Old Mar 13, 2007 | 03:59 PM
kyleb's Avatar
does anyone have an estimated cost on retrofitting and e-locker if all of the parts were bought from a Toyota dealership against if the the axle or 3rd was salvaged?
-Kyle
Old Mar 13, 2007 | 04:11 PM
4low's Avatar
the place I'm getting all my parts from (ECU, rear axle, wireing harness, switch) quoted me $1000. Canadian
those are salvaged parts....not sure about new stuff.
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
