Drag in 4wd
Old Jan 2, 2005 | 09:40 AM
crash's Avatar
Originally Posted by CrazyDiamond
Crash...very possible. The only problem is that if the hub doesn't engage, it is seen to the differential as if the left wheel is spinning (just like jacking up the left side of your truck and putting it in gear...the left wheel will get most of the power with an open differential). SO, theoretically at least, if the left hub is not engaged, the LEFT wheel will get most of the power and the right shouldn't pull like that. It's all because of the setup of an open differential. Still could be a bad hub, and other factors may be in play that I'm not accounting for. Unfortunately, by the way you're describing the harshness of the pull, it sounds like a good look at the hubs and CV joints is warranted.
Adam
Thats the odd part, hubs fully engage(they are stiff but engage), CV's don't bind/make noise. No noise form the front in/out 4wd. Just a distinct pull. It does have a track-lock in the front, granted I have never liked these units, it was in there and will be leaving as soon as I get the d44 built and tossed in..
The only thing I can think is the front diffs is torquing to one side(had a braket fail last winter/break) cusing the pull, but again everything looks good and tight...
Old Jan 9, 2005 | 12:19 AM
Mrs. Crash's Avatar
Ok after a very slow drive home night before last on a skating rink I came home and told Crash we had to figure out what was wrong with my 4 wheel drive. It drove worse in 4wheel drive then in 2. Not only had the pull gotten worse but it was like it would be driving and then lock up, pull the opposite direction, make a bunch of noise like something was breaking and then unlock.. Just thug and let loose. Then drive normal for a while. Then lock up again, pull to the left again etc.. Finally I said screw it and took it out of 4 wheel drive and crawled the rest of the way home in 2 wheel drive. Today he took apart the hub and discovered it had frozen up. So he took it apart and cleaned it out and that solved at least some of the pull. It doesn't pull as hard now. But I'm not sure if it solved the rest cause the ice is melted off the roads now so I can't retest how it handles on the icy roads.
Old Jan 19, 2005 | 05:29 AM
Mrs. Crash's Avatar
Ok problem solved. New tires and it drives like a dream. I finally broke down and bought new tires since mine were so bad and now I have no pull whatsoever and it drives like a whole new truck. Someone said I probably had a bad belt.. Anway it's all better now. Thanks for all the suggestions.
Big Little Bear
230
Nov 13, 2023 11:42 AM
kawazx636
Oct 6, 2021 03:03 PM
tylermx71
Sep 29, 2015 08:49 PM
dbollier123
Sep 29, 2015 05:23 PM
Cycles
Sep 29, 2015 06:37 AM
