Do it yourself?
Re: Do it yourself?
Originally posted by pinoy
Do it yourself job?
Do it yourself job?
How did you do this? Is it the entire thing or just one side?
If you talking of removing that bumper piece 4 bolts are all that holds it on. I need to do mine on that side because it's rusting where the exhaust exits. See you've got Flares.. Like em?
That's weird it's sagged in that direction. Most are the opposite from hitting the bumper on the ground when climbing a hill. If your that concerned with it take it off and tweak the mounts a bit. If you look under there there's not much to the mounting system.
I assumed your picture was about the bumber, the gap at the right is greater then the left (either that or it was assembled by GM or Ford)
Joey, do you think it would be just the mounting brackets that need to be reworked a little?
Originally posted by Jay
Loosen just the side that is tweaked and see if you can move it then. May require someone to lift while you tighten the bolts.
Jay
Jay
I'll bet that does the trick!
