Do it yourself?
Old Dec 27, 2002 | 11:09 AM
pinoy's Avatar
Do it yourself?
Do it yourself job?
Old Dec 27, 2002 | 11:18 AM
kctopher's Avatar
Co-Founder/Administrator
Re: Do it yourself?
Originally posted by pinoy
Do it yourself job?
Ugh, well minus the loads of information you included I'd say yes, depending on how much dmg there is (which looks minimal) you can do most of it yourself..
How did you do this? Is it the entire thing or just one side?
jx94148's Avatar
What are we supposed to be looking at? The saggy rear end? The little scratch by the taillight?
Old Dec 27, 2002 | 11:19 AM
UKMyers's Avatar
If you talking of removing that bumper piece 4 bolts are all that holds it on. I need to do mine on that side because it's rusting where the exhaust exits. See you've got Flares.. Like em?
Old Dec 27, 2002 | 11:22 AM
pinoy's Avatar
Love the flares. Is the bumper supposed to sag like that?
Old Dec 27, 2002 | 11:25 AM
UKMyers's Avatar
That's weird it's sagged in that direction. Most are the opposite from hitting the bumper on the ground when climbing a hill. If your that concerned with it take it off and tweak the mounts a bit. If you look under there there's not much to the mounting system.
Old Dec 27, 2002 | 11:31 AM
kctopher's Avatar
I assumed your picture was about the bumber, the gap at the right is greater then the left (either that or it was assembled by GM or Ford)
Joey, do you think it would be just the mounting brackets that need to be reworked a little?
Old Dec 27, 2002 | 11:37 AM
UKMyers's Avatar
Chris ya I am sure that's all it is. I doubt the whole bumper would be tweaked but I guess it's a possibility. The factory mounts aren't much...
Old Dec 27, 2002 | 11:44 AM
pinoy's Avatar
lowered Rice Rocket... I think it loosened my bumper while rising and falling when i pull forward.
Old Dec 27, 2002 | 11:45 AM
Jay's Avatar
Jay
Ok stop with the nut shots.
Jay
Old Dec 27, 2002 | 11:48 AM
UKMyers's Avatar
Jay
LOL
Old Dec 27, 2002 | 11:50 AM
Adam F's Avatar
Just grab ahold of the underside of the bumper and pull it up. That should get rid of the gap. Or drag it on some rocks.
Old Dec 27, 2002 | 11:51 AM
kctopher's Avatar
Does your corner jiggle? ugh, well does it appear to be loose?
Chris
Old Dec 27, 2002 | 11:57 AM
pinoy's Avatar
This is totally tight and on there. Not loose at all. Tried to pull it up, but i ended up pulling the whole rear end.
Old Dec 27, 2002 | 12:01 PM
Jay's Avatar
Jay
Loosen just the side that is tweaked and see if you can move it then. May require someone to lift while you tighten the bolts.
Jay
Old Dec 27, 2002 | 08:43 PM
butnut's Avatar
Jay
Mr Fix-it strikes again... I'll bet that does the trick!
Old Dec 27, 2002 | 09:10 PM
Cebby's Avatar
Jay
I thought it was time for another bout. Nuts on the left bumper vs. nuts on the right bumper.
Old Dec 28, 2002 | 04:46 AM
Jay's Avatar
Jay
Old Dec 28, 2002 | 11:48 AM
butnut's Avatar
Are these what I think they are?...lol
Old Dec 28, 2002 | 12:32 PM
pinoy's Avatar
looks like i'm going to have to remove the bushwhacker FF.
