Do you run high RPM?
Old Oct 6, 2005 | 10:30 AM
  #41
snap-on's Avatar
i usually shift my 3ezv round 3500, if i really need to get up and go i push it to 4500.
If im pulling ill generally pull till about 4K and shift.
I am known to cruse (when towing) at 3500-4K though....
the auto in my 4 runner likes to push it all the way to 5+ befor shifing if your in it
Old Oct 6, 2005 | 11:12 AM
  #42
surf4runner's Avatar
Originally Posted by snap-on
the auto in my 4 runner likes to push it all the way to 5+ beforE shifing if your in it
normal driving shifting is under 3000. i haven't hit the top speed redline, yet. the speed limiter kicks in b4 it does
should not be any problems keeping it just below redline, just dont drive for a 1000mi with like that.
Old Oct 6, 2005 | 11:34 AM
  #43
paddlenbike's Avatar
Originally Posted by RustBucket
hey that's a great graph! Is there one for the 4-cyl?
I have one for the turbo 4:
Here's another one for the 7M-GE and 7M-GTE Supra motors:
I have a few more for other 6 cylinder Toyota engines but cannot find them right now.
Old Oct 6, 2005 | 11:41 AM
  #44
celica's Avatar
Originally Posted by Bumpin' Yota
btw - is 6000rpm on 3.0 considered high? with 265,000 miles on the clock? My toy knows I love it! Of course the oil is usually changed every 2400 miles too....lol
The rev limiter cuts in around 5500 rpm
Old Oct 6, 2005 | 02:21 PM
  #45
phorunninduke's Avatar
Nice graphs Paddlenbike. Maybe it is the turbo "feel" but I would have swore the 22rte was more powerful than 3vge. Or is that graph for a newer 6cyl?
Old Oct 7, 2005 | 09:50 PM
  #46
Bumpin' Yota's Avatar
Nope! I have an auto and it lacks any kind of revv limiter. Redlining it to 5800rpm is no problem. In neutral I have accidentally revved it to 6500...I thought it was in gear and punched it...
Old Oct 8, 2005 | 08:43 AM
  #47
TRDOLMAN's Avatar
With the blower, my 3.4 makes the most torque around 3600 rpm. Yes I have seen redline plenty of times. This engine seems bullet proof if set up right. Notice this is dyno run number 50.
Old Oct 9, 2005 | 08:59 AM
  #48
X-AWDriver's Avatar
The Toy's Supra motor has to be on e of the strongest engines out there in stock trim as even my friend's '97 laid down just over 700whp on the stock internals with just a better headgasket and ARP studs to hold the head down at 24psi pumping through a T66 turbo and ran low 10s in Phoenix with power everything,cruise and AC in tact and gets just over 30mpg at a steady 75mph on the highway.
Old Oct 9, 2005 | 09:10 AM
  #49
kyle_22r's Avatar
the 20R and 22R are also very stout engines in stock form, with a forged crank and rods. good for at least 300hp before you need to look at billet rods...
Old Oct 11, 2005 | 04:21 AM
  #50
4mydogs's Avatar
I used to regularly approach redline in my MR-2, but not in my 3.slow. Usually no higher than 4K is needed on acceleration, and I like to cruise at around 3K on the freeway. It's not a racecar, and I need it to last!
Old Oct 11, 2005 | 06:23 AM
  #51
celica's Avatar
My 92 has the limiter at around 5500-5800 but I am a standard. Does this mean that the auto does not have the limiter?
Matt
Old Oct 11, 2005 | 10:28 AM
  #52
TRDOLMAN's Avatar
Matt
The rev limiter on my 04 auto is 5600 rpm.
Old Oct 11, 2005 | 10:34 AM
  #53
dexter's Avatar
i probabaly take mine up to the redline a few times daily with no problems (except need a new clutch)
Old Oct 11, 2005 | 03:59 PM
  #54
I certainly wouldnt mind a revv limiter though.
Old Nov 16, 2005 | 09:03 PM
  #55
maxxjq's Avatar
not sure how to make a new thread, question about 22re redline
what is the actual redline of the stock 22re. i already know the peak hp rpm, i just want to know the redline.
Old Nov 16, 2005 | 09:44 PM
  #56
superjoe83's Avatar
on the factory tach it is 5500
Old Nov 16, 2005 | 10:05 PM
  #57
crappled's Avatar
uhm, i think mine idles under 2k... that's the only time it sees that haha
Old Nov 17, 2005 | 07:43 AM
  #58
stevenassco's Avatar
NO it does not hurt the motor to rev to 5K+
YES there is a factory rev limit set at 5600 i believe
YES obviously its not good for a engine to redline all the time
you cannot just ask such a basic and simple mechanical question as "does it hurt it to redline"? Sorry that is something my fiance would ask no offense
how far a engine can rev, hold together at RPMs etc is based on many different variables.....head valvetrain componatry is key and how it is capable of holding revs - what the springs are like etc. The factory puts in Factory rev limits so you can not overrev lets say and drop a valve. I have not experience ANY valve float up the the limiter (bouncing off it actually), so I surmise that Toyota has enough spring pressure in the stock springs to be good for what
I have not delved into the the 5VZ-FE engine yet. Anyone know what the interals are? Forged pistons? Powdered rods? There is not much info out there like there is for my supra and mustang
smthwsn357
May 1, 2024 07:28 AM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
88runnergomas
Jul 9, 2015 01:12 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
