Do You Have An AFR Gauge?
Old Feb 22, 2015 | 09:45 AM
oregon taco's Avatar
Do you have an AFR gauge?
If so, what brand?
Where is it grounded?
Where is it drawing power from?
Where is the controller mounted?
Old Feb 23, 2015 | 09:14 AM
Texas_Ace's Avatar
I do, only needed if you are boosted and then only if something more then a stock pulley TRD supercharger. Not needed at all on 01+ trucks.
Search around for a good deal on a wideband, most work fine, check review for whatever you find.
Follow the instructions for wiring, power from the battery through a fuse is good, switched power through a relay wherever you can find it, cigarette lighter in most works.
Mount it wherever you want. I prefer out of the way installs nowdays. I actually prefer widebands that don't have gauges myself, just hook it up to a computer/phone when you are tuning, otherwise it is just in the way.
Old Feb 23, 2015 | 07:37 PM
sleeper2002's Avatar
I have an AEM wideband setup and love it. Very fast response, easy to read and accurate. I also like the interchangeable bezels and face plates. I ran a relay and power point setup: I used a 20 amp capacity relay and wired (coil side of relay) it to the cig lighter. The other side of the relay (high amp draw side) is wired to power a small (5 location) fuse block on the firewall, this way the gauge is on a switched source. The ground is on the firewall using a simple ground block. As for the gauge, I mounted it using the 2 pod setup from Lotek.
Old Feb 24, 2015 | 08:41 AM
vasinvictor's Avatar
I have the same AEM wideband. I have done everything this guy ^ did. Relay on a switched ignition source. The gauge is just wedged in the front left windshield between the dash and windshield. It's right next to my progressive meth controller gauge.
Old Feb 24, 2015 | 08:44 AM
Texas_Ace's Avatar
You should totally get a piller pod. You can get universal ones that work, thats what I am using. Way better then just shoving them someplace lol.
Old Feb 24, 2015 | 08:46 AM
I know, this truck is gonna nickle and dime me to death.
Old Feb 25, 2015 | 02:31 AM
Robb235's Avatar
If you have a California emissions truck, it has a wideband up front, and you can use an OBD2 scanner, and correlate the reported voltage to AFR using this chart.
Old Feb 27, 2015 | 01:12 PM
Do you have the link for that table? I tried to look at the picture, but it's a little fuzzy
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
dbollier123
Sep 29, 2015 05:23 PM
