disable the cold start enrichment?
Old Dec 15, 2004 | 03:59 PM
TRunner's Avatar
How would I go about doing this? As of now I am rather sure it is stuck "on" even when I pull the wire to it. My engine is running rich and it has now fouled my plugs. I don't want this to happen again and until I can get another cold start enrichment injector, I am stuck doing this fine tuning. Any suggestions?
BTW - I could use any help since I need to get this fixed as it is my only daily driver as I have my wife's Durango torn apart right now. Thanks!!!!
Old Dec 15, 2004 | 04:10 PM
gwhayduke's Avatar
There is some reason it is stuck on if it is. Is your check engine light on? It must be receiving bad information from any of several sensors: temp, egr, O2, etc.
Old Dec 15, 2004 | 04:53 PM
TRunner's Avatar
Pulling the wires should allow it to turn "off" though correct? I haven't had an error code since the rebuild, but it is deffinately runnign rich.
Old Dec 15, 2004 | 05:30 PM
gwhayduke's Avatar
You'll have to plug them back in before starting up in the morning or you'll never get it started. Then do a search on here about testing your O2 sensor, and the others as well.
Old Dec 15, 2004 | 05:31 PM
mike_d's Avatar
check out this thread:
https://www.yotatech.com/forums/f2/1986-22re-ecu-pinouts-46518/
YotaTruck1986 has a link to the ECU pinouts for the 22re (of course i wasn't paying attention to what engine you have). if you unhook STJ then the ecu won't be able to tell the cold start injector to turn on.
Old Dec 15, 2004 | 06:04 PM
TRunner's Avatar
The problem is... It doesn't turn off when I try this, though.
Old Dec 15, 2004 | 06:06 PM
TRunner's Avatar
Yeah, but I think it is an actual problem with the injector itself. Even when I detach the wire harness it still stays open and runs rich. I think I just need to hurry up and replace the cold start injector....
Thanks for the help guys! Anyone have a working used one they wanna send me for Christmas?
Old Dec 15, 2004 | 06:53 PM
callmej75's Avatar
I know on my 3.0....don't know if this applies...but my cold start injector wires run back to the cold start injector time switch...which then...i guess runs to the ecu. the time switch senses that your motor is cold so it sends a signal to the injector which in turn helps ya start on the chilly mornings. You can OHM the time switch to see if its within specs. The specs are 30-50 OHMS below 50 degrees farenheit and 70-90 OHMS above 68 degrees and thats on V6 and 4 cylinders 1988 and up.
Old Dec 15, 2004 | 10:27 PM
phorunninduke's Avatar
PM Red 85 he is parting out my truck for me.
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
Doug4320
Mar 24, 2018 10:11 PM
Jonny246
Jul 12, 2015 04:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
