Directions to replace an air/fuel sensor
Old Jul 5, 2007 | 10:14 AM
kato's Avatar
I did a search and couldn't find it, but is there directions on how to replace an air/fule sensor? And how hard is it?
Thanks
Old Jul 5, 2007 | 10:23 AM
Kaleb's Avatar
Thanks
Like an Oxygen Sensor? MAF?
Old Jul 5, 2007 | 03:25 PM
Skrillah's Avatar
Get under the truck and look on the exhaust pipe and hopefully you should be able to figure it out. Unscrew and then screw and pull the EFI fuse to reset the system.
Old Jul 5, 2007 | 04:01 PM
ScubaDuck's Avatar
I think Skrillah's description is entirely adequate, but if you want more info:
http://www.4runners.org/writeups/02sensor/index.html
The only hard part is forking over the $ for a new sensor.
-Scubaduck
Old Jul 9, 2007 | 03:21 PM
RunnerUp's Avatar
just remember your a/f sensor is before the cat, and since you say you have an a/f sensor, makes me think you have a cali edition, so you might have two cats
Old Jul 9, 2007 | 07:19 PM
kevin444's Avatar
i have one for sale, if needed dirt cheap p]m me
Old Jul 10, 2007 | 06:29 AM
GhostriderTx's Avatar
Not sure on that. I have a 2001 4WD 4Runner with the 3.4 that I bought new in Texas. I was at the dealer last week and priced out the sensor. From my serial number they told me I have an A/F sensor not an O2 sensor. The cost was much higher and like I said this was not a Calif vehicle.
Old Jul 10, 2007 | 07:03 AM
Beartracker's Avatar
My 0-1 Tacoma is not a Calif. addition and it has a A/F sensor. It checks the Air /Fuel flow ratio and most all Tacoma's have them. I could be wrong but that's my understanding. Don't know why it would have anything to do with Calif restrictions.
Anyway, It's between the cat and the engine and it has 2 nuts on it. You will also need to order a new gasket as most of them do not come with the gasket and they don't bother to tell you that. You may have to spray the nuts with something like rust blaster a few times to get them loose. You will also need a small screw driver to undo the disconnects to the wires.
When you replace it do yourself a favor and put some never seize on the new nuts and on the studs before you replace it. It will save you allot of head aches down the road. It's also a good idea to spray the electric contacts with some kind of cleaner and sealer while your at it.They book says it should be replaced every 70,000 miles. Hope this helps, Mike
Old Jul 10, 2007 | 09:32 AM
RunnerUp's Avatar
my truck was purchased new (8 miles on the odo) in florida and is a california emissions vehicle. look under your truck and see of you have two cats, just cause it wasnt purchased in cali doesnt mean its not a cali restricted vehicle. i am pretty sure that non cali 4runners have two O2 sensors and no A/F sensors.
Old Jul 10, 2007 | 10:38 AM
ScubaDuck's Avatar
According to the Underdog Racing Development website, all 2001 and 2002 Runners use the same A/F sensor. (Part # 234-9002 which is the the same A/F sensor used by 1999 Cali-spec 4Runners.) Prior to 2000, it appears that non-Cali 4Runners used different sensors, but since Ghostrider has a 2001, he does have a A/F sensor, regardless of Cali/Non-cali.
You can look at the Underdog Racing parts list by model year here:
http://www.urdusa.com/product_info.p...s_id=430006000
-Scubaduck
Last edited by ScubaDuck; Jul 10, 2007 at 08:09 PM. Reason: Edit- Typo - PN is 234-9002 per URD site
Old Jul 10, 2007 | 05:38 PM
The 2001 is very confusing. Sparkplugs.com shows a Denso 234-9002 not 9001. The local dealer shows a part number of 89467-35011 for my VIN. Anyone have a website that cross references Toyota to Denso?
Old Jul 10, 2007 | 08:11 PM
ScubaDuck's Avatar
Sorry Ghostrider- I mis-typed. The URD site also shows the part # for a 2001 as 234-9002, the same as sparkplugs.com. Fixed it now.
-Scubaduck
Old Aug 15, 2009 | 05:04 AM
Runnin on Empty's Avatar
for anyone looking for a denso / toyota part # cross reference:
http://www.densoaftermarket.com/cata...=Oxygen+Sensor
87turboPA
Jul 12, 2015 07:49 AM
jon.r
Jul 11, 2015 03:34 PM
smiley52
Jul 11, 2015 05:16 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
